Old 12-20-2021, 12:54 PM #16
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Originally Posted by daprotege5 View Post
i looked up parts#'s for frames
v6 frame 51001-3M510
v8 frame 51001-3M460
does anybody know if the frames are swappable???
Best guess is no based on different p/ns. Also, and this is anecdotal only, but I just had a conversation in the forum with someone who was also installing RCI's t-case skid plate. My truck is a V6 and theirs is a V8, and the plates are different lengths. Since they bolt to the frame, that suggests the frames are dissimilar.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 03:13 PM #17
V8Man's Avatar
V8Man V8Man is offline
V8Man will become famous soon enough V8Man will become famous soon enough
V8Man's Avatar
@daprotege5
As far as I know the frames between a V6 & V8 are different only at the engine motor mounts welded to the frame.The transmission cross piece is different but they are bolted on.
The first picture is a V6. Second V8.
frame swap help-2003-v6-resized-jpg  frame swap help-2003-v8-resized-jpg
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
V8Man is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 09:46 PM #18
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
There is also another part number for a 4TH gen frame...it says it's for the V8 if you scroll down to "Part Fitment"......51001-3M520
51001-3M520 Genuine Toyota Frame Sub-Assembly
I don't know what the difference is in the 2 different part numbers for the V8 frames is, if any, it's possible that there's differnce in a 2WD and a 4wd, but that info isn't on any dealer's website that I saw.
I don't know for sure what the difference is between a V8 and a V6 frame but as V8 Man said where the motor mount to the frame are for sure different.
2004 Limited V8
Old 12-21-2021, 10:30 AM #19
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
found this frame about 2 hours away, i called and not much detail on it, asked her if it was in a collison says she believes it only lit on fire. would this work for a frame swap??
frame swap help-burn-jpg
daprotege5 is offline   Reply With QuoteReply With Quote
Old 12-21-2021, 12:20 PM #20
V8Man's Avatar
V8Man's Avatar
LKQ in Oklahoma City has two 4th Generations in their you-pull-it yard. One is a 2004 V6 the other is a 2008 V8.
Old 12-21-2021, 09:35 PM #21
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Yea that looks good - at first I was all sort of confused - what is that I front of the crash bar and then I see it’s a bull bar that’s toast. The radiator support looks clean
It’ll be a ton of work to swap, but assuming no other issues with that donor - looks like it might be worth th drive to see
Old 12-22-2021, 11:08 AM #22
the vehicle is in a co-part facility and can only be purchased through online auction; which in Florida you have to have a license to do so. So not running into any luck on much information on it, as have to have this and that to even look at it.
Old 12-22-2021, 02:12 PM #23
V8Man's Avatar
V8Man's Avatar
@AuSeeker
The transmission crossmember is different between the V6 and V8. I have had them both on the floor togethe. The V6 is taller, but they both bolt into the same place and are interchangable on the frame. The 4WD bolt in too.
frame , good , swap , truck , wanted
In the middle of the frame swap: what’s the Part Number for the fuel/brake line to frame retaining clips? cl4Rk 3rd gen T4Rs 12 04-23-2021 03:43 PM
3rd gen frame swap services New England? mickeyt 3rd gen T4Rs 6 12-12-2019 02:03 PM
Frame Swap Eric J. Robertson 3rd gen T4Rs 23 06-06-2015 06:34 AM
Frame swap???? Thurlo76 Classic T4Rs 2 05-07-2010 01:23 AM
Frame swap travisvon81 General Discussions 1 12-08-2009 08:47 AM
