Old 12-23-2021, 02:36 PM #1
TN4Runner07 TN4Runner07 is offline
TN4Runner07 is on a distinguished road
Cold WEATHER Idle Issue
Hello All! Having an issue with my wife's 2006 T4R SR5 V6. We live in Montana and temps having recently dropped to 8-10F overnight. When I start the vehicle in the AM, it has a super rough idle and cannot seem to find a proper RPM upon start up. I am able to apply gas and reach about 1200 RPM for about 1 min and it will begin to idle just fine. Subsequently, it will throw various misfire codes with a CEL light, VTRAC light. I am able to reset every time. I have tried to search other sections, but have not found anything regarding cold WEATHER starts. Just COLD starts. I am specifically looking for guidance with what I need to be looking at when temps drop. I have cleaned and will replace the PCV valve with new tubing as it was moderately cracked at one end. Before I start throwing plugs, wires, O2 sensors at the problem, wanted to touch base with everyone to see if anyone else had the same issue! Thanks so much for the help or guidance!
_______________________________________________199 9 4Runner SR-5, 230,000+ Miles, BFG A/T
TN4Runner07 is offline   Reply With QuoteReply With Quote
Old 12-23-2021, 06:40 PM #2
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Check your battery, if it's past its best it won't like the cold and could be affecting the operation of the ECU and resulting in these weird errors you have.
An easy thing to check before you tear anything apart, at least!
And check your earth points too. The traction control light coming on makes no sense for an engine issue
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 12-23-2021, 07:21 PM #3
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Clean all the related sensors you talked about and the throttle body, iac. I did mine at 100,000. The upstream a/f sensors take about that long to warm up especially if the pre heat element isn't getting power or is ****ed up.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 12-23-2021, 09:04 PM #4
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
Not sure your 4Runner has one but if it has an air flow control idle valve that might be the problem.
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 12-23-2021, 11:41 PM #5
325runner 325runner is offline
325runner is on a distinguished road
Check for a leaking head gasket. Coolant leaking into the cylinder will pool up after the vehicle has been sitting and will cause a misfire when started, clearing up shortly after its been running. I would pull the spark plug on the affected cylinder misfiring and inspect in the cylinder while cold (with a borescope if possible) if not try and get a peek down inside if possible or check for wetness
325runner is offline   Reply With QuoteReply With Quote
Old 12-24-2021, 01:50 AM #6
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Iac idle air control sensor is on the throttle body on the 2010 also the throttle position sensor. Not sure about yours. Use a sensor safe cleaner like maf cleaner on sensors.
Old 12-25-2021, 04:56 PM #7
The G-Man The G-Man is offline
Real Name: Gary
The G-Man is on a distinguished road
Real Name: Gary
This.
The G-Man is offline   Reply With QuoteReply With Quote
Old 01-03-2022, 04:15 PM #8
Ok, thanks everyone! It looks like it is consent with the P430 code along with the above mentioned. So thinking about checking for exhaust leaks first, then moving to O2 sensors?
cold , idle , issue , start , starts
High idle on cold starts on cold days texadelphia 3rd gen T4Rs 8 10-12-2021 04:43 PM
Cold starting and poor initial idle issue octanejunkie 3rd gen T4Rs 35 10-08-2019 02:23 PM
cold idle issue stackz 3rd gen T4Rs 12 10-24-2013 08:48 AM
Cold Idle Issue rcharris 3rd gen T4Rs 3 10-18-2009 08:15 PM
Can idle at start up in cold weather be adjusted? ssjetset Problems & Warranty Issues 2 12-18-2007 07:20 PM
