Old 01-03-2022, 08:42 PM #1
blkexp98 blkexp98 is offline
blkexp98 is on a distinguished road
Question Air Suspension Removal Questions
Im debating on replacing my rear air suspension with coils and was curious for those of you that have done it would you do it again? I really dont have any problems with it but the bags are getting old and I live in AZ now so that isnt going to help the rubber last any longer. How does the ride change after doing the swap? Ive watched some videos on the swap as well as the conversion kits and it looks pretty simple so im not concerned about the work itself. The bags are nice for towing but and the leveling feature has come in handy. I know I can add helper spring air bags to get that back if I wanted to but just dont know the other changes ill discover.
Thanks for any help.
2007 Limited 4Runner
4x4 V8
blkexp98 is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 04:54 PM #2
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Most people just leave it in place if it's working fine, unless you want some lift or need better load support. Coils would feel firmer (in a good way) with less body roll, but you do lose that cool features you have now.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 10:25 PM #3
shastaliu shastaliu is offline
shastaliu is on a distinguished road
Thanks for the information. It really helped me!
shastaliu is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 08:50 AM #4
KrazedJD's Avatar
KrazedJD KrazedJD is offline
KrazedJD is on a distinguished road
KrazedJD's Avatar
After removing my air suspension and replacing it with toytec lifted coil springs I will say I did not initially miss the air ride. Over time I felt the ride was similar without load to the air ride. where I notice the biggest difference is under load. Towing or carrying a full truck with people and tools or bags, the coil springs are not as good. I have had to spend a little extra to add airbags to the coils to resolve the sag under load.
Side note, the air system Toyota chose is top notch and similar design but not size to the air system found in commercial trucks with a redundant overlap design and heavy reinforced rubber. After removing mine I admired the design used compared to the GM crap I have seen in the past.
KrazedJD is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 10:30 AM #5
Crikeymike's Avatar
Crikeymike's Avatar
I've had a lot of people come back and buy helper air springs to add into the coils, after they switched from OE airbags to coils. It sounds like most people really do notice the difference big time compared to the old setups.
Old 01-11-2024, 11:54 AM #6
Flash Runner's Avatar
Flash Runner Flash Runner is offline
Real Name: Blake
Flash Runner is on a distinguished road
Real Name: Blake
Crikeymike! I'm about to pick up an '08 with the OEM RAS, and plan to replace it with a Dobinsons Kit to get a lift and better off roading.
I've been doing some searching but it seems a lot of old links are broken. Do you think I'll have any major problems doing this swap, or finding certain parts to do it? Do I need too (or should I) rip out the whole system (i.e compressor, tank, motor and dryer) or just replace the shocks and coils?
TIA
22 SR5 Prem 4X4- Magnetic Gray
07 V8 Limited 4X4 - Natural White (SOLD)--> "Moby Dick" Build Thread
Flash Runner is offline   Reply With QuoteReply With Quote
Old 01-11-2024, 12:04 PM #7
Crikeymike's Avatar
Crikeymike's Avatar
TIA
Hey bud
When you shop for a full kit on our site, it gives the option to add the airbag conversion kit. That with the coils and shocks is all you need.
Dobinsons Lexus Airbag Conversion Kit for Lexus GX470 GX460
And no, you don't "have to" rip out all the other stuff, but if you're removing the bags with no plans to go back, you may as well remove it, as you're just carrying dead weight.
Here are the kit options: Full Kits - 4th Gen 4runner Archives - Exit Offroad
air , bags , handy , suspension , swap
Fender liner removal questions FoneRunner 3rd gen T4Rs 10 05-03-2018 12:06 AM
Rear air bag suspension removal - LTD OWNERS soundstudio315 4th Gen T4Rs 9 07-19-2017 11:27 PM
CV axle shaft removal/install questions fourfive 3rd gen T4Rs 16 06-02-2015 12:17 AM
Crankshaft bolt removal questions! Amirocassar 3rd gen T4Rs 4 09-22-2014 11:02 AM
Alternator Removal, belt length and more questions! HowardRoark 4th Gen T4Rs 2 12-23-2012 10:23 PM
