Old 01-05-2022, 02:59 PM #1
yert33 yert33 is offline
yert33 is on a distinguished road
1GR-FE with 320K miles - How long till doomsday?
My 2004 SR5 has never had a valve job, timing chain or rings replaced AS FAR AS I KNOW. I bought her at 140K, 320K now.
Have been chasing and "solving" lean bank 1 then lean bank 2 then lean bank1 for a couple of months now. By solving I mean replacing the cats, servicing the injectors, then most recently replacing the bank 1 downstream O2 sensor. New shop (to me) did a leak down test and reported that #3 probably needed rings. They recommended replacing the engine in light of the high mileage and that I want to keep the vehicle as long as I can. (The rest of the vehicle is very clean and functional. Knock. On. Wood.)
I don't mind replacing the engine as I suspect that the timing chain, valves, etc MUST NEED some attention just from the number of miles on her. And it's been 1200 miles since the last "fix", the O2 sensor, was made. No CEL since then. The fuel trims are little higher on bank 1. And she is running great at the moment.
Question: Drive until it gets bad enough to replace engine or be proactive and bite the bullet now?
Discuss....
yert33 is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 04:17 PM #2
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
I'd drive it until things get worse but may start looking for a lowish mileage used engine so you're prepared. I do wonder if it's mainly the timing chain/tensioners that are giving you these issues. I think there's a simple way to check chain stretch. Maybe throw a bore-scope down the plug hole to check the cylinder walls especially on #3.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-05-2022, 08:24 PM #3
Thanks for the reply, Mike.
What would one be looking for on the cylinder walls? Confirmation of the poor leak test, i.e., rings are bad? Would I be scratching my head harder if the walls look good? Ha ha!
Old 01-06-2022, 07:02 PM #4
Asylvester Asylvester is offline
Asylvester is on a distinguished road
Just drive it. I would however get a second opinion, especially if you are looking at getting a new motor. I’m surprised at failing rings. I see these motors with 400/500 thousand miles on them. If you are going to spend that kind of money definitely get a second opinion!
Asylvester is offline   Reply With QuoteReply With Quote
Old 01-07-2022, 10:44 AM #5
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
i would say, it's your timing chain. how much oil consumption do you get?
Discuss....
4r-4ever is offline   Reply With QuoteReply With Quote
Old 01-07-2022, 07:52 PM #6
Sorry, got distracted by my daughter's Hyundai.
Asylvester: 400-500K, huh? That sounds awesome. Second opinion sounds logical.
4R-4ever: Little to no oil consumption. bSuppose I could remove the tensioner cover and see how far out it is?
Thanks for the replies.
2004 V6 SR5
Old 01-07-2022, 08:17 PM #7
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Downstream is after the cat, is that what you mean? Because that only reads emissions, doesn't affect the mix. Both banks though so your issue is most likely a vacuum leak regardless. Leakdown tests are pretty easy, consider getting a gauge and doing one yourself, or definitely get a second opinion without telling them anything prior. Not to say it can't happen and I haven't done much with the 1GR, but never seen more leakage from rings than valves if both are untouched
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 01-07-2022, 09:52 PM #8
Yes, the O2 sensor not the upstream A/F sensor. Good advice, jvtbt. Think I'll get the leak down gauge.
2004 V6 SR5
Old 01-08-2022, 07:40 AM #9
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
If there is little to no oil consumption that is great news, your rings and valve stem seals must surely still be in good condition. I am not an expert but just going on what I have read from general interest on here, another vote to get the timing chain condition verified.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 01-08-2022, 10:19 AM #10
Yup. These are pictures posted on this very forum! There are more but I did not want to take up too much space.
1GR-FE with 320K miles - How long till doomsday?-6c0f8479-b788-4ecc-a942-6185dbd55233-jpg  1GR-FE with 320K miles - How long till doomsday?-dd538fed-721e-47c9-9384-ecc6199888b4-jpg
Old 01-08-2022, 10:46 AM #11
When we bought our 2009 4Runner it had 156K miles on it. My wife’s friend thought we were crazy buying a car with that many miles on it. They don’t know Toyotas. They drive other brands (I’m being nice here by not identifying the brand). But their idea of life expectancy out of a car is much less, and for good reason because their cars don’t go that long. So it’s worth fixing, even at that mileage. Please keep the post updated with your findings as I’m very curious to know. Thanks and good luck!
Old 01-09-2022, 01:58 AM #12
Miranthis Miranthis is offline
Miranthis is on a distinguished road
Almost 300K on my 2008 v6 SR5 and I plan on driving it until 400K+....or as long as it goes.... 😁 Change the oil and do the maint. and it will take care of you.
Jeff-in-KC
2008 4Runner SR5 V6 4x4 Dark Blue
2011 & 2012 Camry I4s
Miranthis is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 04:59 PM #13
MikeinNH67's Avatar
MikeinNH67's Avatar
You would see gouges on the cylinder walls if there is a broken ring. As mentioned that usually comes with oil consumption and or extra blow-by into the crankcase. Second opinion is definitely a good idea on the compression test.
Mike
03 4runner Limited
Old 01-13-2022, 01:58 AM #14
zameul40's Avatar
zameul40 zameul40 is offline
zameul40 is on a distinguished road
zameul40's Avatar
I rebuilt my 2004 V6 engine which came out of a wreck i bought to replace the locked up engine in my sons 04. When i actually got inside the engine the 280K mile rod and main bearings actually looked better than the new ones i put in it and believe it or not i pulled out the micrometer and the original bearings were a tiny bit thicker than the replacement bearings.
zameul40 is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 12:44 PM #15
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
OP, you ever send your oil for analysis? That might help rule out issues. I was just talking to "my parts guy" at the dealership I usually go to. I asked about rebuilt transmissions, just to get an idea so if I ever need to do that. I decided to ask if Toyota does remanufactured engines. Again, just for background info. He seemed to think it was better to go to an engine shop, from what I gathered. I guess because theyight have more info on sourcing engines. Apparently near me, there's someone who can import low mileage engines from Japan. And then further, I suppose that's because Toyota is still using the 1Gr-Fe, in my case.
2008 SR5 4WD
bob3dsf is offline   Reply With QuoteReply With Quote
bank , engine , lean , miles , replacing
Doomsday Prepping your 4Runner masphx 3rd gen T4Rs 65 04-16-2017 12:59 PM
Picked up a 99' TFR SR5, 320K MILES. Where should I start. Odin_ 3rd gen T4Rs 7 02-23-2015 07:30 AM
How long till rebooting CV isn't viable? Atrox Caeda 3rd gen T4Rs 5 06-08-2014 05:11 PM
Factory Oil...change it at 1500 miles or let it ride till 5000?? Boaz 5th gen T4Rs 29 07-12-2012 05:14 PM
Long time 'till overdrive kick in normal? 95 2WD 4runner Maintenance/Detailing 1 05-07-2006 11:33 PM
