Old 01-06-2022, 05:50 PM #1
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
2004 Rear Suspension Too Stiff
Need some help picking replacement REAR springs... current setup is a bit too stiff, but height is good.
Currently installed =OME 2895
(~ 2" lift, for 400lb of extra weight or less, 260lb spring rate)
I need help picking a replacement. I want it back to something that feels pretty stock, while maintaining the same 2" lift.
I don't carry a heavy load when off-roading or wheeling anymore.
I don't care which brand, as long as it works well and is good quality.
Thank you
Old 01-07-2022, 05:27 AM #2
ohshi ohshi is offline
ohshi is on a distinguished road
A lot of people go with the toytec rear springs to keep a 2” lift and softer ride. I don’t have experience with toytecs but I’m on the same ome 895s. They do break in a bit. They’re much less stiff nowadays or I just don’t notice. When I first installed them I definitely agree they felt too stiff.
ohshi is offline   Reply With QuoteReply With Quote
Old 01-07-2022, 10:35 AM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Shocks can play a roll in how stiff a vehicle feels. We swapped out just the rear shocks in a buddy's FJ from Icon to OME long travel and the rear felt noticeably stiffer.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 01-07-2022, 01:59 PM #4
Bumbo's Avatar
Bumbo's Avatar
I've had them on the truck for like 4-5 years... I used to do a lot more off-roading with a heavy loadout, but have not done that for a couple years. Rear has always bucked over bumps when unloaded.
Thanks for the recommendation. Ill check that out.
Old 01-07-2022, 02:01 PM #5
Bumbo's Avatar
Bumbo's Avatar
Rears are Bilstein 5100. I gave this consideration as well, but I still think the springs are the primary source.
If that still doesn't get what what I want, ill revisit the shocks.
good , lift , picking , rear , replacement
Suspension Sagging with the added Armor - What Rate Spring? jimmyrecluse 3rd gen T4Rs 14 06-05-2020 03:01 PM
Spring Rate Question jpaws 5th gen T4Rs 7 02-27-2019 03:36 PM
Spring Rate and suspension information Porqupine82 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 10-27-2017 10:47 PM
ICON Spring rate AZTOY 3rd gen T4Rs 7 07-18-2017 02:05 PM
Spring rate question ron in sc 5th gen T4Rs 12 04-02-2012 05:24 PM
