Old 01-18-2022, 02:42 PM #1
Moist's Avatar
Moist Moist is offline
Moist is on a distinguished road
Moist's Avatar
Exclamation Front wheels beginning to camber in.
I'm not too sure why it's happening. I'm not the most well versed in cars.
Recently the front wheels began to gain negative camber, without any adjustment from me.
It's starting to look a bit worrying. How would I fix?
Moist is offline   Reply With QuoteReply With Quote
Old 01-18-2022, 05:13 PM #2
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
There are a lot of things it could be, and none of them are good. My best bet would be a failing upper or lower ball joint, or the LCA bolts not being tight anymore.
Any of these things can cause a catastrophic failure that puts you in a ditch... If you aren't comfortable with it, I'd get it to a mechanic ASAP.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 10:00 AM #3
Moist's Avatar
Moist's Avatar
Alright. Thank you for the response. Could also be why the steering's becoming funky.
Old 01-19-2022, 10:24 AM #4
Moist's Avatar
Moist's Avatar
If you don't mind me asking, how would I check these at home. (Just to make sure)
Old 01-19-2022, 11:53 AM #5
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
I would start by lifting the front end and tugging on the wheels to see what components behind them move. Whatever is not solidly in place is the culprit. If you're going to get this fixed, consider having the car towed in.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 12:27 PM #6
To get a good look, you will need to lift the front of your vehicle on a jack until the wheels droop. Try to shake each wheel. The only play should be in the steering going in and out. Anything else is bad.
Are both wheels cambered in? Or just one? If its just one, take a good look at the top and bottom of the spindle, and where the LCA meets the frame. These are your three most likely trouble spots. They should look the same on both sides. If one appears to be sitting at an odd angle, its a good chance that is your culprit.
Old 01-19-2022, 01:11 PM #7
Moist's Avatar
Moist's Avatar
Alright, when I've got time here soon I'll check it out.
Old 01-20-2022, 07:45 PM #8
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Same here when my front springs sagged due to age at 250K miles, front tires were wearing on the inboard treads noticeably. When I replaced the front struts & springs, I had alignment checked and it was in spec. Rotated the tires and put another ~12K on them before replacing them, the fronts (previously rears before rotation) had no additional wear on the inboard treads.
So, how's your front ride height and how old are your front springs?
waypoint is offline   Reply With QuoteReply With Quote
Old 01-24-2022, 03:01 PM #9
Moist's Avatar
Moist's Avatar
I apologize for not having replied in a bit. Been busy lately.
"To get a good look, you will need to lift the front of your vehicle on a jack until the wheels droop. Try to shake each wheel. The only play should be in the steering going in and out. Anything else is bad. Are both wheels cambered in? Or just one? If its just one, take a good look at the top and bottom of the spindle, and where the LCA meets the frame. These are your three most likely trouble spots. They should look the same on both sides. If one appears to be sitting at an odd angle, its a good chance that is your culprit." -gimilithepirate
Both of the front wheels are cambering in. Just from looking at the lower ball joints it looks alright. the tie rods look good too, but I can't prove that anything is good. I do not have the ability to lift the vehicle, so I'm bringing it in. (needs new brakes, wiper fluid tank has a hole in it somewhere, and a loud whine is coming from the engine.)
"Same here when my front springs sagged due to age at 250K miles, front tires were wearing on the inboard treads noticeably. When I replaced the front struts & springs, I had alignment checked and it was in spec. Rotated the tires and put another ~12K on them before replacing them, the fronts (previously rears before rotation) had no additional wear on the inboard treads. So, how's your front ride height and how old are your front springs?" -waypoint
I haven't noticed any uneven wear, (although I haven't owned it long enough to confirm or deny that)
The front springs have never been touched, factory from 2003. (at least to my knowledge)
The front is noticeably lower than the rear (about an inch by eyeballing it), but it may appear that way from the bent skid plate. I'm not sure the exact numbers, but it's noticeable. The car is sitting at 186K miles, daily driven since 2003, been in an area that gets snow often. So quite a bit of rust caked on everything.
Old 01-25-2022, 10:25 AM #10
Front is supposed to be an inch lower than the rear. That's so your nose isn't in the air when you load the back up with your monthly Costco run
That said, the fact both are cambering in is a little puzzling to me. My best bet would be sagging suspension that's just plain worn out, without an alignment in a very long time.... but its pretty weird that its symmetrical. Parts that control alignment are "per side," so the only two things connecting the front wheels in an IFS rig are the steering shaft and the anti sway bar.
Old 02-04-2022, 01:39 PM #11
Moist's Avatar
Moist's Avatar
Smile
The car is back and the results are here. The Ball joints are in good condition, same with the tie rods and control arms (albeit a fair bit rusted).
Both the front and back sit about half an inch lower than where they should be. The front right is the lowest, and it corresponds to an accident the vehicle was in where a knuckle and control arm were torn off the FR wheel.
The front right wheel was out of alignment.
Otherwise the suspension is just plain old. I'll probably fix it if I have the time and money. After all It's not unsafe, just old and I really don't plan on going off the road anytime soon.
Thank you guys for your help.
camber , front , starting , wheels , worrying
FS: 4th GEN - 2X Moog Front Lower Control Arm Camber Kit K100128 EdmundGTP For Sale: T4R Items 0 06-11-2017 08:06 PM
Front caster camber bolt set quote. calcrc 5th gen T4Rs 6 02-09-2016 07:16 PM
Camber issue after Tundra front??? Fochps 3rd gen T4Rs 8 02-03-2013 09:39 PM
Where do you buy your tools for checking front camber at home on your 4runner? mom 3rd gen T4Rs 29 08-16-2012 04:40 PM
