Old 01-18-2022, 07:32 PM #1
cassato cassato is offline
cassato is on a distinguished road
4wd actuator reassemble help
2006 v6 SR5
I had been having some issues with my 4wd not engaging and found some posts on how to troubleshoot the actuator / free it if it is seized. I was able to get the housing open and initially marked where the gears were and got it back together. I tried a few times and could hear things moving but I must have messed up putting it back together. I noticed that the shaft on the top with the teeth (sorry I don't know all the part names) has moved in and out as I put things back together and try again, so it seems like things are powered and not seized up, but out of place. On my last attempt to put it back together the large gear (which I thought was 1 piece) came apart and after trying to get it back together the 4x4 green light is on and 4Lo is flashing while in 2. When I put it in 4H the green light stays on and 4Lo starts flashing, when I put it in 4Lo the lights stay the same but it starts beeping (as tho I attempted to put it in 4Lo and it failed to do so). Is there anywhere online that outlines how to put the gears back in line with the switch, or does anyone have any tips? I found a few used parts on eBay, wondering if it might just be worth swapping it out if getting the placement is too tricky.
cassato is offline   Reply With QuoteReply With Quote
4lo , back , light , put , things
Door Actuator or Fob Issue? (One Actuator Already Replaced) Mlynn 4th Gen T4Rs 6 06-28-2022 12:02 PM
Preventative maintenance for front diff actuator and/or center diff lock actuator NJ-4Runner 3rd gen T4Rs 12 04-22-2021 11:26 PM
4th Gen Actuator, Help! SHagood 4th Gen T4Rs 11 01-22-2020 11:08 AM
Rear Axle Reassemble- Play in Backing Plate blarchitect 3rd gen T4Rs 2 03-31-2017 10:25 AM
4Lo actuator faqoldschool 4th Gen T4Rs 6 09-23-2012 12:12 AM
