Old 01-19-2022, 02:11 PM #1
Mr_Dobalina Mr_Dobalina is offline
Mr_Dobalina will become famous soon enough
Codes Codes Codes Codes....
Started up my car this morning and almost every warning light came on.
Check Engine Light, traction control, VCS Off, VCS Trac all on.
I went to Auto Zone to get the codes checked.
P0455 Evaporative Emmision Control System Leak Detected (I am hoping this was just the loose gas cap)
P0441 Evaporative Emission Control System Incorrect Purge Flow
C1201 Brake Boost Sensor Circuit Range/Performance
C1233 Malfunction in ABS Control System
C1241 Low Battery positive voltage or abnormal high battery positive voltage (I put in a new alternator and battery this past fall. When the dude check the battery and alternator he said everything looked good.
C1290 Malfunction in zero point of steering sensor
It's a 2007 4runner 161,000 miles.
The only unusual thing I have done lately was jump start my wife car last night.
I also changed the brakes this past fall did not encounter any issue.
Any ideas on where to start looking?
Mr_Dobalina is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 07:50 PM #2
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
Do a quick search for How To Perform Zero Point Calibration here on the forums That should clear up the C1290 Malfunction in zero point of steering sensor code at least.
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 01-20-2022, 08:42 AM #3
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
I would suspect that this code flurry could be caused by your battery voltage dropping during the jump start. Make sure you battery is charged, clear the codes and see if they come back.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 01-25-2022, 08:59 AM #4
Well, I did not do a thing and all the warning lights went away. Magic.
Old 01-25-2022, 10:20 AM #5
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
I recently experienced the same deal...but mine was a fuel cap issue...whoops...I'm glad you got it figured out! Ha!
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 01-25-2022, 07:36 PM #6
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
You say you didn't do anything....not even get any gas/fill up?
If you got gas maybe when you put the gas cap back on it sealed better.
2004 Limited V8
Old 01-26-2022, 11:13 AM #7
I did get a fill-up and made extra sure to make sure the gas cap was closed. I just found it odd that the codes auto reset without me having to do it manually.
Old 01-26-2022, 03:10 PM #8
theoutbackdream's Avatar
theoutbackdream theoutbackdream is offline
Real Name: Matt
theoutbackdream has a spectacular aura about theoutbackdream has a spectacular aura about
Real Name: Matt
How low on fuel were you?
I couldn't imagine a gas cap throwing all those codes at once, unless you were (maybe) very low on fuel, and potentially starving the motor.
2007 Limited V6 4WD Build Thread
Find me on Instagram @t4r_explorer
theoutbackdream is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 03:06 PM #9
All the lights came back on this morning. I topped off the tank last night.
I am thinking its the gas cap so I threw a 16 dollar Advanced Auto Parts cap on it.
Hopefully this does the trick.
Old 01-27-2022, 03:07 PM #10
Real Name: Matt
Real Name: Matt
Highly recommend you get an OEM cap. Aftermarket caps don't seem to seal as well. I got my OEM cap for $20 shipped.
battery , codes , control , system , voltage
C1223/C1256 abs codes on scanner but no engine codes or lights keakar 4th Gen T4Rs 4 04-22-2019 02:37 PM
Common Codes? "Historic Codes"? Should I care? Okusputokus 5th gen T4Rs 0 02-11-2019 06:52 PM
We heard you like OBD codes so we added codes to your codes thinkCooper 3rd gen T4Rs 47 01-29-2017 12:54 PM
