Old 01-21-2022, 10:17 AM #1
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Window rubber strip replacement
Just noticed this part has perished and split, are they easy to replace and are they a generic item?
Cheers!
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 02:06 PM #2
SurferUK's Avatar
SurferUK's Avatar
I can get pattern part replacements easily enough for the 5th gen on AliExpress, anyone know if they would be backward compatible?
Looks like 4th gen would have to come from the USA with increased postage.
Old 01-21-2022, 05:39 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
They are very easy to replace, roll down the window remove one screw and pull it back and up, do the hatch as well, it usually goes bad before the doors, no screws on the hatch just roll down the window and pull up to remove.
I doubt that 5th Gens pieces will work but I don't know for sure.
2004 Limited V8
Old 01-21-2022, 05:52 PM #4
gtojimbo's Avatar
gtojimbo gtojimbo is offline
Real Name: jim
gtojimbo is on a distinguished road
gtojimbo's Avatar
Real Name: jim
i just replaced all of mine a couple of months ago. mine's a 3rd gen and i did'nt even need any tools, really easy!
99 sr5 manual 4 wheel drive
gtojimbo is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 06:09 PM #5
SurferUK's Avatar
SurferUK's Avatar
Thanks mate, I will keep hunting.
Cheers for that!
Old 01-21-2022, 09:24 PM #6
ClimberGuy ClimberGuy is offline
ClimberGuy is on a distinguished road
If you have time, can you share where you end up getting it? I need to replace this part as well. Thanks!
ClimberGuy is offline   Reply With QuoteReply With Quote
Old 01-22-2022, 06:26 AM #7
SurferUK's Avatar
SurferUK's Avatar
Hey mate, in the end I just went with your side of the pond
GENUINE OEM TOYOTA 03-09 4RUNNER FRONT & REAR DOOR GLASS WEATHERSTR SET | eBay
To be fair the price is reasonable for an OEM part.
Old 01-31-2022, 11:31 AM #8
Shanran71 Shanran71 is offline
Real Name: -Shannon
Shanran71 is on a distinguished road
Real Name: -Shannon
thanks for the link... I need to do this.
Shanran71 is offline   Reply With QuoteReply With Quote
Old 01-31-2022, 10:13 PM #9
sk.huckleberry sk.huckleberry is offline
sk.huckleberry is on a distinguished road
Contact the parts department at your local Toyota dealer. Mine were in stock and the same price as Amazon. Added benefit - genuine Toyota parts.
sk.huckleberry is offline   Reply With QuoteReply With Quote
Old 02-01-2022, 11:31 PM #10
maxdef maxdef is offline
maxdef will become famous soon enough
Just to add from my experience, it's worth peeling back the bottom section of the plastic barrier to check that none of the old weatherstrip pieces broke off and fell into the bottom of the door. In 4 out of 5 of my windows, I had some level of old rubber gunk blocking a drain hole.
Also, I ordered all OEM replacements, though it wasn't too pricey as I got them from Cobb County toyota who has ~30% off, like some other dealerships, as well as free shipping over $75.
maxdef is offline   Reply With QuoteReply With Quote
Old 02-02-2022, 01:25 PM #11
SurferUK's Avatar
SurferUK's Avatar
My local dealer would look at me as if I had turned up in a UFO! (It's not an officially imported model here)
Old 02-05-2022, 11:49 AM #12
firefight1981 firefight1981 is offline
firefight1981 is on a distinguished road
I want to add my experience with replacing the window weather stripping for all four doors.
Ordered all four parts from oem parts source dot com.
The process is pretty simple, but not exact.
Meaning, I would unscrew one score on each door, have to pull/tug/wiggle thr stripping to get it out.
Reversed the process when adding the new one.
Once you get the new one put in and properly aligned, shut your door and press down pretty firm, and you will hear the weather strip click into place. Keep doing this until it is nice and snug along thr door.
firefight1981 is offline   Reply With QuoteReply With Quote
Old 02-05-2022, 11:53 AM #13
Almost forgot...
Make sure you CLEAN OFF the area where the new weather stripping will be.
Might be another 5+ years before these need to be replaced again, and getting that dirt and grime cleaned up will help longevity of this vehicle.
Old 02-05-2022, 12:28 PM #14
SurferUK's Avatar
SurferUK's Avatar
Originally Posted by firefight1981 View Post
Almost forgot...
That's a very good point, stuff like that will soak up moisture and cause rust. Cheers!
Old 02-14-2022, 08:58 PM #15
jas8650 jas8650 is offline
jas8650 is on a distinguished road
Just got a set of 4 windows in Rock Auto for 100 delivered. Good quality and fit well. Very easy to install.
jas8650 is offline   Reply With QuoteReply With Quote
cheers , generic , item , replace , window
Rear door window exterior rubber (Not rear hatch) replacement? Quiero 4th Gen T4Rs 3 01-01-2019 07:38 AM
4runner just came out of the car wash and black rubber strip hanging minimalist 5th gen T4Rs 14 10-26-2016 09:57 AM
Rubber strip on roof buzzing cstokes86 4th Gen T4Rs 2 05-27-2014 02:30 PM
Right rear window reg. & rubber channel replacement 77'911 Classic T4Rs 0 05-18-2012 05:37 PM
Rubber strip on the roof flies off in car wash JosephD05 4th Gen T4Rs 21 05-03-2006 03:27 AM
