Originally Posted by maxdef
I recently replaced the front 2 diff support arms (the bushing is part of the arm, go figure) and tried to inspect my rear support some but didn't notice anything concerning. Out of curiosity, where did you see a mention that it's poly? Just surprised as I expected more rubber for that.
I had this same issue recently- clank noise on any imperfect road and no space between the bottom of the diff and top of skid plate. Turns out the shop I had it in recently took off my skid plate and didn't replace the 2 front spacer washers, bringing the whole skid angling up. One of the washers actually survived an all-day drive sitting on the skid plate! All this to provide a little perspective, just check that nothing is going on with the skid as well
You are probably correct with it being rubber and not poly. Sorry wrong terminology. Maybe I will have to look into replacing the front 2 supports as well. Mine is definitely sagging bad so I need to do something for sure.
