Old 01-24-2022, 09:32 PM #1
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Running 285's without BMC
Currently running E rated 255/80R17 Toyo Open Country AT II's. Looking to run 285/70R17's because I want a bit of a softer ride with C rated tires. I have stock SR5 wheels (pictured below), spidertrax spacers, and JBA upper control arms.
If anyone is running 285's without a BMC, what's your suspension/wheel setup (wheel specs, caster, etc)?
Not opposed to getting a BMC, but would like to avoid if not necessary.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 01-24-2022, 09:39 PM #2
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
You'll be able to run it if you drive straight and barely turn. If you flex it off road you will rub like crazy without a bmc.
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 01-24-2022, 10:38 PM #3
ohshi ohshi is offline
ohshi is on a distinguished road
If you take out the spacers then you won’t need a bmc.
ohshi is offline   Reply With QuoteReply With Quote
Old 01-24-2022, 11:54 PM #4
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I’m running 285/70r17 Milestar Patagonia M/T tires on 17x8 American Racing AR893 wheels with +25 offset and 1.25” Spidertrax spacers. Caster is factory spec. I have a 3” suspension lift in the front plus a 1” body lift. No body mount rubbing yet, but I haven’t flexed the suspension either (all on-road). I have bought BMC plates, but I haven’t done the BMC yet. I will in the spring/summer just to be safe.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 01-25-2022, 12:39 AM #5
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
285s probably won't clear the UCAs on the +30 wheels, but I believe they will on +15 wheels like the newer 5th gen wheels. If you run spacers on the +30 wheels, it will bring your effective offset to -1.75 and cause more scrub radius than you want to maintain the body mount
High caster ucas are actually not helping fitment at the body mount. They restore the caster figure by leaning the spindle back in the wheel well, which in turns brings the tire closer to the body mount
You could run SPC arms, push the LCAs forward with the cam bolts, and use the SPCs to do the alignment. You'd probably still be able to get 3* of caster, but the wheels would be further forward in the wheel well. This is how I run 35x10.5s without having to cut my body mount, except I'm running a bit lower caster to keep the tires out of the fire wall.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 01-25-2022, 01:51 AM #6
carlodonz's Avatar
carlodonz carlodonz is offline
Real Name: Carlo
carlodonz will become famous soon enough
carlodonz's Avatar
Real Name: Carlo
I have Dobinsons 2.5", SPC UCAs, FN wheels -10 offset, running 285/70/17. No BMC and no rubbing at all.
2014 4Runner Trail Super White
carlodonz is offline   Reply With QuoteReply With Quote
Old 01-25-2022, 05:00 PM #7
but you have a 5th gen?
07 SR5 4x4
Old 04-21-2022, 05:58 PM #8
Blute Blute is offline
Blute is on a distinguished road
This is a good thread, but wondering for myself...
I installed JBA UCAs with my approx. 3.5" lift and have the 7.5" wide stock rims w/ 30mm offset. Thinking about getting some 285s, but I believe this would require wheel spacers to clear the UCAs, so I would likely go with 1.25" spidertrax. So the question is this - if I go this route, and also try to max out caster close to 4 degrees, would I still need a BMC to get the tires to fit? I know experiences vary a lot, but just wondering what folks think about this setup.
2006 4Runner Sport V6: Eibach Pro-Truck/Wheeler's T1/T12 lift | JBA UCAs | 265/70R17 BFG KO2 | 5th Gen Brakes | Spidertrax | Clearbra | WeatherTech mats
1998 4Runner SR5 V6 (SOLD): 265/75R16 Duratracs | Taco Whip Antenna Mod | Tundra 199mm Brakes | Tundra TRD Front Coils/OME 890 Rear Coils/Bilstein 5100s | CBI Rear Plate Bumper | Center Console Mod
Blute is offline   Reply With QuoteReply With Quote
Old 04-21-2022, 11:24 PM #9
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I ran 285/70R17 Nitto Terra Grapplers on stock Sport wheels without much issue long time ago? Was with a 3 inch suspension lift before I got my body mount lift for my 35's. Though I had a front bumper so I didn't need to trim the fronts and I was running aftermarket upper control arms (SPCs at the time I think?)
I think it's somewhere in my build thread?
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 04-22-2022, 12:31 PM #10
Inv4drZm's Avatar
Inv4drZm Inv4drZm is online now
Inv4drZm's Avatar
Angle grinder is $15. Add some cutoff wheels, goggles, and gloves. So like $25. Sell the angle grinder when you are done for like $5 at a garage sale.
BMC done for $20.
But at one point I had 285s that didn't rub the stock body mounts so it is possible.
Inv4drZm is online now   Reply With QuoteReply With Quote
Old 04-22-2022, 03:22 PM #11
Berty_K's Avatar
Berty_K's Avatar
BMC done for $20.
did you not weld a cap on your bmc?
Old 04-22-2022, 04:27 PM #12
Inv4drZm's Avatar
Inv4drZm's Avatar
No I don't see the point.
285s , bmc , rated , running , upper
WTB: 5th gen Trail edition running/TRD Pro/Off-Road running boards BIGpharma Want to Buy/Trade 5 05-04-2020 02:10 PM
Those running LC 7 wraps in the rear, what coils are you running up front? the walrus 3rd gen T4Rs 13 03-08-2019 03:08 AM
truck running rough after not running at all 4fishrunner Classic T4Rs 5 06-28-2012 03:53 AM
WTT: '06 Sport Running Board/Tubes for SR5/Limited Running Boards thirstyturtle Want to Buy/Trade 6 09-14-2011 06:38 AM
