Originally Posted by eleven14
Wow, it's even a deep socket. Assuming you're going to go ahead and overhaul (timing chain, etc.) since you're in that deep? What year?
was discussing this with my right hand mechanic friend that always helps. I'm thinking the previous owner tried his hand at doing the timing belt and the water pump, as he caked RTV everywhere.
Should i be concerned with the metal ring/shavings i found in the oil pan?? definitely need to clean the screen/filter in the pan.
my logic of thinking is, if i drove it home an 1hr in the bad shape it was, motor should still be in solid condition, would that be correct to assume??
