Old 02-01-2022, 02:24 PM #1
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
timing off?
so have the infamous timing cover leak so have been tearing down and inspecting everything along the way. Took pictures just to verify but i believe previous owner had timing off. Top is the right cam, which is the one that i believe is off, bottom is passenger side.
timing off?-image0-copy-jpg  timing off?-image1-copy-jpg
daprotege5 is offline   Reply With QuoteReply With Quote
Old 02-01-2022, 06:30 PM #2
delstele's Avatar
delstele delstele is offline
delstele is on a distinguished road
delstele's Avatar
If the truck ran fine before then it depends on the order of fire the motor is in ATM. You need to check alinement @ TDC on cylinder #1..
delstele is offline   Reply With QuoteReply With Quote
Old 02-03-2022, 02:10 PM #3
Everything lines up and my passenger cam is off by a tooth. From researching a lot of people have trouble lining it up on install. Pulled plug#1 and confirm piston is indeed lined up Tdc
owner , pictures , previous , timing , verify
4.0 V6 How do you check the timing chain set up with the timing cover on? mopar346 4th Gen T4Rs 11 12-03-2021 11:36 PM
3rd Gen Timing Marks for Timing Belt Replacement FTW1996 3rd gen T4Rs 4 10-01-2015 04:00 PM
help pls - timing belt or timing chain? weifert Maintenance/Detailing 2 10-22-2012 07:12 AM
New timing belt, no timing marks... toylocost Classic T4Rs 6 08-08-2009 05:25 AM
Adjusting timing on 22R-E engine without a timing light Sidney Classic T4Rs 0 08-15-2008 09:29 PM
