Old 04-16-2024, 05:57 PM #1
JackDuggan JackDuggan is offline
JackDuggan is on a distinguished road
New rear caliper sticking - MC booster? brake hose?
I noticed my rear brakes were getting quite a bit hotter than the fronts. I took off the rear calipers and discovered one was stuck, driver's side rear so I replaced both. Now that side seems normal but the passenger side rear is hot enough to sizzle water while the other three are just warm.
I replaced the brake hoses at the corners and all the calipers, pads and rotors four years/40k miles ago. I didn't replace the two center rear hoses though.
I'm wondering if this is more likely to be the center hoses collapsing or the MC, booster accumulator assembly. There are no lights on the dash. Could the system be preventing the brake fluid from returning on one side only? And would there be a warning light if it's the MC?
I'll probably go ahead and replace the center hoses, as that's probably the last possible fix I'd want to do myself, but I was hoping to see if someone had some advice. Thanks in advance.
2008 V6 RWD SR5
JackDuggan is offline   Reply With QuoteReply With Quote
Old 04-16-2024, 07:11 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Are the calipers you bought new or remanufactured?
Did you lube the caliper pins?
Bad MC wouldn't affect just one caliper, replace the center hoses (hopefully the other hoses you replaced 4 years ago are still good) and if the problem is still there then you have a bad/stuck "new" caliper, or bad/dry pins that are hanging up the pads.
2004 Limited V8
Old 04-16-2024, 09:17 PM #3
Thanks. The calipers were rebuilt, from Advance Auto. They moved easily on the slide pins. I didn't take the pins out as they were together with the bracket when I bought them. This is the first vehicle I've had with this type of braking system. I was accustomed to replacing front pads twice before having to do the rears, but the rears on this have worn twice as fast as the fronts.
2008 V6 RWD SR5
Old 04-17-2024, 07:14 AM #4
Real Name: Skip
Real Name: Skip
It's normal for the rears to wear out before the fronts, it is speculated that it's because Toyota designed it so the rears engage first to minimize nosedive when braking.
2004 Limited V8
Old 04-17-2024, 12:46 PM #5
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
The first thing I'd look at are the calipers and the possibility that they're hanging up. Why you say? Because parts store rebuilt / remanufactured parts are notorious for poor quality right out of the box. I can't begin to tell you how many I've seen problems with.
And the sliders are not the only thing that can cause a caliper to hang up. I actually had a "remanufactured" caliper from Advance a number of years ago that looked pretty good, but locked up right away. I pulled the piston out to find it almost totally corroded. Yea, they rebuilt that one.
There can be several problems with this type of caliper. First, was the core that they rebuilt an actual Toyota part or an aftermarket part? Second, what kind of parts did they use in the rebuild process? Most of the rebuilt ones use junk components. Third, what was the actual process that they used to rebuild them. The word "sketchy" comes to mind here.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 04-17-2024, 04:43 PM #6
I bought them from Advance Auto. I usually go through RockAuto but I didn't feel like waiting. Afterwards I looked at RockAuto and saw I could have gotten new ones for the same price I paid for rebuilt. Although I'm not sure what the quality would be for a $65 new caliper.
2008 V6 RWD SR5
Old 04-17-2024, 05:29 PM #7
FoundedSine14's Avatar
FoundedSine14 FoundedSine14 is offline
FoundedSine14 will become famous soon enough
I had an issue with calipers sticking on my 1973 VW. The rubber brake hoses were deteriorating and it caused an issue like you're describing.
I don't know if that's the case here, but considering the age of the vehicle it probably wouldn't hurt to replace the rubber hoses.
2008 SR5 | Build Thread
2006 AutoX Camry | Build Thread
FoundedSine14 is offline   Reply With QuoteReply With Quote
Old 04-17-2024, 08:55 PM #8
Thanks. I did replace the outboard hoses four years ago, but I didn't do the two inboard rear hoses. They would be 16 years old now. I'll do that first and remove the sticking caliper; hard to believe it would go bad in two days and maybe 30 miles of use.
2008 V6 RWD SR5
Old 04-17-2024, 11:00 PM #9
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
It may never have worked properly since it was reman'd.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 04-18-2024, 07:29 AM #10
72W442 72W442 is offline
72W442 is on a distinguished road
I had the exact same issue on my right rear caliper of my 06 4runner I thought for sure it was a problem with the hose or master cylinder but it ended up being the cardone ultra rebuilt caliper it was just junk ,My guess it would be a caliper
72W442 is offline   Reply With QuoteReply With Quote
brake , center , hoses , rear , side
2006 V8 AWD limited brake issues sticking caliper Mayhem988 4th Gen T4Rs 0 08-22-2017 06:49 PM
Sticking Caliper Piston, Sticking Rear Shoes, or ABS? nc-grayson 3rd gen T4Rs 1 07-05-2017 08:19 PM
Another sticking caliper, parking brake issues viggen337 4th Gen T4Rs 5 11-23-2014 09:09 AM
brake caliper sticking? 2002t4rlewis Maintenance/Detailing 8 06-28-2007 08:07 PM
Front Brake caliper sticking? r1burden Classic T4Rs 5 06-05-2005 05:15 PM
