Old 02-11-2022, 09:39 PM #1
chris in ky chris in ky is offline
chris in ky is on a distinguished road
Please help with steering
I'm at my wits end.
Last year my '06's steering started sticking a little, making it dicey driving down skinny roads here in KY. Long story short, it's been to two shops, steering rack replaced twice and intermediate shaft is new. Both shops state ball joints are fine, it still wants to stay in one place if you let go after a turn.
230k miles btw. I don't know what to do now, maybe the dealer? New PS pump?
2006 Sport V6
Bought used @ 185k miles
My first T4R, previous XJ owner
chris in ky is offline   Reply With QuoteReply With Quote
Old 02-11-2022, 10:05 PM #2
Bl4ck4rm4 Bl4ck4rm4 is offline
Bl4ck4rm4 is on a distinguished road
Man that is a head scratcher. I would assume if it was a PS pump (failure, not bled, or old fluid you would have difficulty steering from a stop. However I’m also assuming, you have no electronics going to the rack, all straight hydraulics.
Is anything over torqued in the front suspension to have binding? Are the mount points on the steering rack solid, nothing cracked that would make the rack shift when turning preventing the wheels to go straight?
Just brainstorming ideas
Bl4ck4rm4 is offline   Reply With QuoteReply With Quote
Old 02-11-2022, 11:11 PM #3
It honestly feels like it has half the steering assist of my 2010 Sienna. I jacked both up off the ground and compared, the Sienna can be steered with one finger, the 4runner takes a lot more effort.
2006 Sport V6
Old 02-11-2022, 11:30 PM #4
That sounds like PS pump is going bad, or the new rack didn’t get fully burped, and you got air. Probably wouldn’t hurt flushing the PS fluid with clean fluid.
Old 02-11-2022, 11:52 PM #5
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
They used ATF and not clear fluid, right?
You can try to bleed it out yourself. Spend a lot of time on it and see if it helps. I always take my time bleeding out P/S systems. Air can cause damage in your gear boxes and it’s a lot of work and money to deal with that.
Any chance you tracked down an actual Toyota rack and pinion?
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 02-12-2022, 12:41 AM #6
Ok wow, you guys aren't gonna believe this.
I checked the reservoir and not only is it mostly empty but there is this light pink strawberry milkshake/pepto bismol substance in there. I put some on the plastic housing lip and it's definitely not aeration, some sort of contaminant. I'd post a pic but it's not letting me.
The shop wanted to "try another vendor" for the rack but the factory Toyota is priced at $1300 and he's not willing to eat that cost yet.
2006 Sport V6
Old 02-12-2022, 01:24 AM #7
That’s it, you need a good flushing. As someone said earlier, it uses ATF. Which is usually strawberry red. Now why it looks like a milkshake, I wander whoever did the work, if they used something else besides ATF. Normally when anyone describes a milkshake looking substance, it normal comes from two things that don’t belong together, such as blown head gaskets or oil coolers. But is sounds like you got something water based or different substance in your PS reservoir/ pump and rack.
The real question, is going to be do you raise hell for them to correct the problem or do you avoid them like the plague?
Old 02-12-2022, 01:50 AM #8
I've come to the conclusion they don't know how to fix this, third rack and multiple attempts to fix what was just supposed to be a stiff intermediate shaft.
2006 Sport V6
Old 02-12-2022, 10:48 AM #9
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
Tell us a little more about your truck. Is it lifted? Suspension or body lift? Aftermarket control arms? Have you checked the steering shaft? Maybe the u-joint in the intermediate shaft is binding up?
DIY: Power Steering Flush (4th gen specific)
If you have the means maybe this power steering flush will help.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 02-12-2022, 11:39 AM #10
None of the above matters.
They mixed clear and ATF and it’s destroying all your components.
Flush it completely. Get some good ATF, fill it, bleed it, and I’ll bet it solves your problems.
Clear fluid does not provide the necessary lubrication ATF does.
Now, a quick and easy way to flush this is to remove the belt, pull the return hose, hook an impact to the ps pulley and turn it clockwise. It will pump all the fluid out of the gear box/rack and shouldn’t damage anything. I would personally do two cycles of ATF to make sure it’s all out.
You can also bleed systems like that without worry of running low on start up. Fill the reservoir and then hit the pulley with the impact and top off as needed. Then do the process or turning the wheels back and forth once it’s full.
I’ve rebuilt quite a few full power steering systems. Never have an issue.
Old 02-12-2022, 01:06 PM #11
@ at this point, I wouldn’t put it pass the shop on the work that was done.
I would the flush, that is given . If the problem is still there then look at the intermediate shaft. I honestly agree with you that flush will solve the problem, just thinking of plan B for the man in a case it doesn’t solve
Old 02-12-2022, 02:54 PM #12
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Sometimes, people open the hood and troubleshoot before they post.
waypoint is offline   Reply With QuoteReply With Quote
Old 02-12-2022, 07:35 PM #13
Sometimes, people ask cause they don’t know where to start troubleshooting. Please help with steering
Old 02-12-2022, 08:16 PM #14
waypoint's Avatar
waypoint's Avatar
Agreed on your recommendation of a complete flush as the next step, just grab a gallon jug of Dexron-III compatible fluid at the parts store (I've had good results with Valvoline Dex-Merc) and go to town.
Aftermarket rebuilt steering racks are a sore subject with me, I've been burned on these junky parts and avoid them.
Old 02-12-2022, 10:22 PM #15
Agreed, mine has always been reman. Alternators, they are like scratch-off lotto tickets. Had 6 replaced under lifetime warranty in one year on one car.
After the first replacement At the shop chris has work done on the truck, I would have chalked it to a defective rack, the second time, I would have made sure everything was done to factory, before writing it off as a second defective, then would have ate the cost of a new rack for the customer. This day in age, majority of shops have access to repair guides, whether they are getting them from Snap-on or Matco scanners (via subscription) or bought a cheap online version of a chiltons.
fine , joints , shops , stay , steering
Intermediate Steering Shaft Replacement - fixed steering clunk! Lamer 3rd gen T4Rs 7 08-06-2022 08:00 PM
Loose steering and wobbly steering wheel even after steering rack bushing replacement psyduck 3rd gen T4Rs 18 07-17-2022 07:17 PM
Excessive play on drivers side steering - replace steering rack guide cheeser 3rd gen T4Rs 17 05-05-2022 08:15 PM
replacing intermediate steering column U joint - loose steering jrm 4th Gen T4Rs 4 09-15-2017 05:28 PM
ST001R-05 09/08/2005 Steering - Highway Speed Steering 'Flutter' CBR_GUY_IA TSB 2 11-30-2010 05:45 PM
