Old 02-23-2022, 12:46 PM #31
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
ok, pulled the R13 relay. brake lights inoperable, as well as VSC dash lights did not return upon start up. suppose only option is to source a replacement?
Brake lights constantly on?-thumbnail-jpeg
rwh963 is offline   Reply With QuoteReply With Quote
Old 02-23-2022, 12:50 PM #32
second pic
Old 02-23-2022, 01:41 PM #33
for reference: superseded part number for that relay is 90084-98032. about $45 discounted. it isa denso part, maybe direct buy?
Old 02-23-2022, 01:57 PM #34
jumped on ebay, ordered a used superceded relay with a 1 yr warranty and tested for $10 shipped. better than gambling on a $50 part.
Old 02-23-2022, 02:36 PM #35
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Well you need the relay plugged in for the stop lights to work. It's a switch. That doesn't tell you if it's good or bad. You need to test it before you buy another part dang it. Hopefully that's the problem though.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 02-23-2022, 02:41 PM #36
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Have you tried plugging in another relay of the same prong layout?
Old 02-23-2022, 06:43 PM #37
no, haven't done that yet. been busy today, but did want to return the pedal switch and get the used relay purchase achieved ASAP.
i believe the VSC lights came on the same time the brake lights started running full time. using the same relay.
Old 02-23-2022, 07:09 PM #38
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Yes the stop switch signal is an input to the skid ECU. Did you say that went away with the relay out?
Old 02-23-2022, 07:36 PM #39
Bl4ck4rm4 Bl4ck4rm4 is offline
Bl4ck4rm4 is on a distinguished road
you may have missed the update, but i did buy a new switch, same result. the suggestion is the relay is bad, so i suppose with the ignition on, but brake pedal not engaged, electricity is flowing to the brake lights.
i believe with the ignition off, the brake lights get their electricity directly from the battery. with ignition on, they get their power through that system.
maybe teach can clarify this thinking.
I may have missed that. Look at the wire diagram, check the relay and fuses. Possible relay is stuck in power instead of switching
Might be a little late as I was typing and troubleshooting
Bl4ck4rm4 is offline   Reply With QuoteReply With Quote
Old 02-23-2022, 08:09 PM #40
yes, it did not reappear with that relay pulled.
Old 02-23-2022, 08:11 PM #41
yes, hoping that relay is just stuck open, and the replacement will return things to normal. never had a relay fail in years of driving.
Old 02-23-2022, 10:28 PM #42
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I see 3 other relays in the photo that very well could have the same part number, I would of checked them to see if indeed they have the same part number and if so tried it to see if the brake lights worked properly.
2004 Limited V8
Old 02-24-2022, 09:55 AM #43
moneypit's Avatar
moneypit moneypit is offline
moneypit is on a distinguished road
moneypit's Avatar
Stop Lights on with lights
Many years ago, had the same problem. Tail bulb, 1157 broke dimmer filament and it landed on the stop filament. Thus, brake lights with headlights on. Remove both tail bulbs and reinsert one at a time and see what happens. Good luck
-moneypit
2015 Blizzard Pearl Limited
Black leather interior
moneypit is offline   Reply With QuoteReply With Quote
Old 02-24-2022, 10:25 AM #44
thx for the suggestion, though, in this case, brake lights are on w/o headlights on.
Old 02-24-2022, 10:26 AM #45
day late and a dollar short on that suggestion! replacement will be here saturday, so i think i will let the suspense build.
brake , constantly , lights , true , wondering
Brake lights and dash lights not working, just hooked up new trailer plug MichaelAngelo 3rd gen T4Rs 3 02-15-2015 11:30 AM
Fs: 3rd gen tail lights, corner lights, turn signals, 3rd brake light set with led Stretch1100 For Sale: T4R Items 0 10-06-2011 03:42 AM
2003 Rear Lower Lights into Lighted with Brake Lights neogauge 4th Gen T4Rs 2 07-02-2009 08:55 AM
leds in tail lights, no brake lights, buzzing from dash with blinkers??? jamr1 3rd gen T4Rs 0 09-12-2008 07:10 PM
