Old 02-24-2022, 06:55 PM #46
Bl4ck4rm4 Bl4ck4rm4 is offline
Bl4ck4rm4 is on a distinguished road
Originally Posted by rwh963 View Post
yes, hoping that relay is just stuck open, and the replacement will return things to normal. never had a relay fail in years of driving.
It will be interesting to see if this fixes it. I have seen them fail, not too often, but has happened.
If this doesn’t work, I would trace what all is tied into the brake switch connection.
Bl4ck4rm4 is offline   Reply With QuoteReply With Quote
Old 02-24-2022, 07:15 PM #47
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
day late and a dollar short on that suggestion! replacement will be here saturday, so i think i will let the suspense build.
I know my reply was too late when I posted it but I posted as soon as I saw your photo, the main reason I posted that suggestion was for your future reference if you experience another relay possibly gone bad, also for anyone else that may read this in the future with a similar issue with a relay.
2004 Limited V8
Old 02-24-2022, 07:35 PM #48
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
lighten up, it was meant to be humorous! now if i had spend $1000, i would very upset at your late-to-the-party suggestion! we will find out something when the replacement relay arrives. just checked on the situation again, now that it is dark. brake like functions normally with ignition off, always on with ignition engaged (acc or on).
rwh963 is offline   Reply With QuoteReply With Quote
Old 02-24-2022, 07:56 PM #49
Real Name: Skip
Real Name: Skip
Not sure what in my last reply made you think I was upset, I don't get upset over forum posts, life is too short for that.
2004 Limited V8
Old 02-24-2022, 09:05 PM #50
not upset, just a little serious! thx for chiming in; hopefully issue will be resolved shortly. might even be here tomorrow (even though we will be having a snow storm).
Old 02-25-2022, 04:32 PM #51
UPDATE: good news, the relay arrived today (fast shipping). bad news, it didn't change anything .
the mystery continues. so far down $10 (until i re-sell).
what could it be?!
Old 02-25-2022, 08:17 PM #52
so, need some new ideas. will check the brake fluid level. maybe the pedal spring? don't feel any pedal slack (can't lift it with my toes). is there a sensor somewhere? i had mentioned that i had the rear brakes completely replaced last summer; could there be a wire not re-connected? and remembering that the VSC lights are also running long term (as well as tpms light). don't recall if i changed any rear bulbs last year. i see something about double filament bulbs.
in my personal repair summary, i see that the brake light switch was replaced by me at 200k miles (228k now).
Old 02-25-2022, 08:31 PM #53
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
In the picture next to your relay box i see a rusted trough panel. That indicates to me there may be the same type of thing going on under your relay/fuse box. Next I recommend checking the circuit at the relay female connection on both sides of the circuit with a test light. This should tell you which side of the circuit the problem is on. You can do this at the fuses also to narrow down the trouble area. Remember when using a test light connect to ground to check for voltage. Connect to ground to check for power. Repeat the procedure twice with ignition switch in all positions. This is my method there are other options.. The brake job has nothing to do with this.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 02-25-2022, 08:55 PM #54
i read that some brakes light switches can be adjusted. i didn't know that. makes sense because the switch is used in multiple vehicles. i don't remember adjusting it at 200k (july 2018) miles with the new one. i did not adjust the new one i just tried. heck, maybe the brake lights have been running since 2018! cops will stop you for brake lights out, maybe not for them on unless;ess they are driving behind you.
anyone know if it is adjustable, and how?
Old 02-25-2022, 09:43 PM #55
"In the picture next to your relay box i see a rusted trough panel"
i don't believe anything is rusted through. i see those two rust spots.
Old 02-25-2022, 09:56 PM #56
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Yes there is an adjuster to set the plunger. If your lights are on with the ignition on then they would also be on with it off until your battery died if the plunger was just set incorrectly..
Old 02-25-2022, 10:02 PM #57
Jakeepoo3's Avatar
Jakeepoo3's Avatar
This is a simple circuit too! These circuits get pretty complex and intertwined with each other that's the beauty of the test light and multimeter diagnostic method. It's fairly simple to isolate the problem area within the circuit once you understand how to interpret them and the flow of electricity.
Old 02-25-2022, 10:02 PM #58
also heard ideas that it could be connected to the tow light receiver. it is exposed to the elements. this is the only electrical issue i have.
Old 02-25-2022, 10:05 PM #59
and again, the brake lights work as expected with no key in ignition, and with key in up to ACC. once i turn the key to ON and START, that is were the lights remain on. what's the difference between ACC and ON? something different happens hoping from one to the other.
Old 02-25-2022, 10:09 PM #60
Jakeepoo3's Avatar
Jakeepoo3's Avatar
There's no way I can think of the rust could come from a drip from above so you have a rust issue coming from the other side all the way through..
brake , constantly , lights , true , wondering
Brake lights and dash lights not working, just hooked up new trailer plug MichaelAngelo 3rd gen T4Rs 3 02-15-2015 11:30 AM
Fs: 3rd gen tail lights, corner lights, turn signals, 3rd brake light set with led Stretch1100 For Sale: T4R Items 0 10-06-2011 03:42 AM
2003 Rear Lower Lights into Lighted with Brake Lights neogauge 4th Gen T4Rs 2 07-02-2009 08:55 AM
leds in tail lights, no brake lights, buzzing from dash with blinkers??? jamr1 3rd gen T4Rs 0 09-12-2008 07:10 PM
