Are you looking for the LED bulbs to update the halogens but not sure which LED bulbs will be compatible with your 4Runner? Here we list all the bulbs size for 2006~2013 Toyota 4Runner for your reference. We also list all compatible LED bulbs which have been tested several times and work great.
A Whole Set LED bulbs fit for 2006~2013 Toyota 4Runner
If you would like to try switchback fog lights, learn more details in this thread:
Lasfit Switchback LED foglight bulbs
1. Low beam bulb size: H11
2. High beam bulb size: 9005/HB3
3. Fog light bulb size:
● 2010~2013 4Runner: H11
● 2006~2009 4Runner: 9006/HB4
4. Front turn signal light bulb size: 1156A(single filament bulb)
5. Rear turn signal light bulb size: 7440A(single filament bulb)
6. Rear Brake/Tail light bulb size: 7443R(dual filament bulb) - DON'T fit for 08-09 4Runner
7. Backup light bulb size: 921/T15
8. License plate light bulb size: 168/T10
9. Trunk light bulb size: DE3175 (28mm festoon LED bulbs)
10. Interior dome light bulb size: DE3175(31mm festoon LED bulbs)
11. Interior map light bulb size: 168(T10 LED bulbs)
12. Interior door light bulb size: 168/194(T10 LED bulbs)
NOTICE:These are all OEM bulb size, if you have installed after-market assemblies, the bulb size may be different.
