Old 02-23-2022, 12:16 AM #1
TejasRunner01 TejasRunner01 is offline
TejasRunner01 will become famous soon enough TejasRunner01 will become famous soon enough
Which fan clutch silicone oil to use?
Hello everyone,
I am having some issues with the fan clutch slipping on my 08 V8. For those of you that decided to change the silicone oil out, how much she what cst viscosity did you go with?
On the 80 series ih8mud forums, many are using as high as 50mls of 20k cst silicone oil. I live in a hot state, what would you recommend for this? I've never taken apart a fan clutch but seems like this is a relatively straight forward process. Also in case it helps, the clutch housing is gray, not blue which I believe indicates it is an Eaton.
Thanks!
Sent from my SM-G970U1 using Tapatalk
TejasRunner01 is offline   Reply With QuoteReply With Quote
Old 02-23-2022, 02:41 PM #2
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
I'd jump on car-part.com and see if I could just buy a used assembly.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 02-25-2022, 04:22 AM #3
Bl4ck4rm4 Bl4ck4rm4 is offline
Bl4ck4rm4 is on a distinguished road
I would just go buy a new one. That is what I have done in the past with fan clutches. I wasn’t aware of them being disassembled to drain the oil out of. 20k cst is pretty thick material.
Now it makes me want to find a fan clutch in one of my parts bins to see if it is possible, it’s worth money who is look for OEM for restoration
Bl4ck4rm4 is offline   Reply With QuoteReply With Quote
Old 02-26-2022, 09:41 PM #4
I just finished replacing the fan clutch with a new Aisin kit. In case anybody needs to know the exact model for the 2008 V8, it is FCT-075. There is so much more air pushing in the engine bay now, the original definitely was having issues. I'm going to make a small write up.
clutch , cst , fan , oil , silicone
Manual Swap Clutch Pedal and Clutch Master Cylinder VernySanders 3rd gen T4Rs 5 06-27-2020 11:21 PM
Fan Clutch Silicone Oil Viscosity - Need Recommendation JZiggy 3rd gen T4Rs 0 12-24-2016 05:21 PM
Clutch engagement point on pedal after new clutch and flywheel installed 89FourRunner Classic T4Rs 8 11-18-2016 04:03 PM
Silicone hose... RussToy 3rd gen T4Rs 18 07-27-2015 12:45 AM
