Old 02-24-2022, 04:02 PM #1
wracks03s's Avatar
wracks03s wracks03s is offline
wracks03s is on a distinguished road
wracks03s's Avatar
Speed sensor A
Does anyone know where the hell speed sensor A is!? Been chasing this for months and nobody seems to have an answer....I know there are two on the trans and the 4 wheel sensors. I just cannot confirm which it is!
2003 v8 SR5:custom exhaust,4xInnovations rock rails,,CBI front bumper,Toytec Boss 3/2 lift,UCA's,more to come!
2020 Tundra SR5
1971 duster pro-touring car
1969 Honda trail 70
wracks03s is offline   Reply With QuoteReply With Quote
Old 02-27-2022, 02:06 AM #2
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
There is no Speed Sensor A... Are you chasing a P0500-Vehicle Speed Sensor "A" problem?
This is one of those codes that is kind of not very clear with it's description. Vehicle speed on 4th Gen 4Runners is calculated by the ABS Module by combining the 4 ABS Wheel Speed Sensor inputs and averaging them together. An intermittent P0500 can be caused by one or more of the ABS Wheel Speed sensors not reading accurately and/or dropping out intermittently. It can also be caused by an issue with the ABS Module Communicating with the ECM and/or the Combination Meter (the ABS module reports vehicle speed data to the ECM and Combination meter separately, the ECM uses it for transmission shift logic, engine management, and cruise control; the combination meter uses it for cruise control and reporting vehicle speed).
The easiest way to find out which sensor is causing issues is to get a scantool that can communicate with the Toyota ABS system and pull the live data to see what the wheel speed sensors are reading and to test drive the vehicle and see which one is dropping out/reading incorrectly.
You could also try and look for any damaged/stretched looking abs wires as well as removing the wheel speed sensors and making sure they don't have crap stuck to the tips.
But before all that, could you give a brief history on the issue and when the DTC started occuring?
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 07-21-2024, 08:44 PM #3
wracks03s's Avatar
wracks03s's Avatar
Thanks for the info! Been a while since I have been on here! No idea when it kinda started or why. Still hadn't fixed it,divorce stuff. Anyhow,I have some spare sensors I can just start swapping them out.
2020 Tundra SR5
1969 Honda trail 70
sensor , sensors , speed , trans , wheel
Which Speed Sensor? Sgtausy 3rd gen T4Rs 0 02-12-2018 06:00 PM
ABS Speed Sensor cotect20 5th gen T4Rs 6 01-11-2018 07:01 PM
Wheel speed sensor/wheel speed sensor harness replacement Elan_ 4th Gen T4Rs 1 01-03-2018 07:57 PM
Abs speed sensor help!! Irierasta Classic T4Rs 3 02-28-2012 03:59 AM
ABS Speed Sensor KEFRO 3rd gen T4Rs 3 02-20-2012 08:37 AM
