Real Name: Ron
Real Name: Ron
A waste of $$ IMO. What are you going to do if you get a "bad" report, tear engine down? Only good for fuel dilution and antifreeze IMO unless you are trying to push the limits of oil change interval to over 10K miles and then what you save doing that you spend on oil analysis.
Oil analysis is for the trucking industry where big fleets can save big $$ playing with oils, intervals, etc.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
