Originally Posted by Rapidrob
Turns out the plug is some sort of alloy that does not want to take any rod I have.
I drilled out and tried a large Easy-out, that did not work either. I would of though the heat from the failed welds would have loosened the plug, it did not.
I then decided I would drill out the plug and install a 1/2" pipe plug. After drilling the hole for the pipe tap I started to tap the hole in the plug and the plug moved! Not on CW but on CCW to remove chips!
Thank you Jiffy-Lube for wasting 3 hours of my time.
Now I have to flush out any metal chip's and refill the diff.
I could not prove to Jiffy Lube they caused the problem. Its been too long since Elaine took the SUV to them for an oil change. Been going to a local Ford dealer who does not check the diff oils.
I honestly can’t belive anyone trusts knuckle heads working for minimum wage to actually do their jobs correctly. Most fast food workers screw up orders…just think about that for a second.
I did an oil change for a friend, who took her car to Valvoline religiously…the sludge I found said it hadn’t been drained and changed in a LONG time. She was pissed, but that’s what they do.
