Old 03-06-2022, 08:50 PM #1
Bagels's Avatar
Bagels Bagels is offline
Bagels will become famous soon enough
Bagels's Avatar
V6 Oil Leak Near Timing Cover. Identification help please!
Hello Everyone,
I discovered a small oil leak on the right side of my engine. I originally thought it was the timing cover but it doesn’t seem to be originating from there.
It seems to be coming from where a bolt would go but I can’t find any information on what this spot is for or if a bolt is supposed to go there in the first place.
Does anyone know any information on this issue? I’ve marked the spot in red below.
Background info:
2008 4Runner V6 engine with 123,000 miles. No major work has been done on the engine that I know of.
2008 4Runner
Mod List: Daystar 2.5"/1.5" Lift, BF Goodrich KO2 275/70r17, TRD Pro Rims, Spidertrax 1.25" in front and All Pro 1.5" in rear, Katzkins Seat Leathers, 15% ceramic tint, Joying 10.1" Head Unit, Remote Start, DRL Mod, Map Light Mod, Dash Cluster LED Upgrade, Area Camp Lights.
Bagels is offline   Reply With QuoteReply With Quote
Old 03-06-2022, 10:03 PM #2
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
theirs a post timing chain cover, i couple of us have gone through it in the last couple months. its known for leaking at that spot. not a fun task to take care of, if your doing it yourself.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 03-08-2022, 01:34 PM #3
Bagels's Avatar
Bagels's Avatar
After cleaning the area and re-inspecting I’m still not sure where the leak is coming from. Looks like it could be a leak between the block/header or at the timing cover. Part of me still thinks it coming from the mystery circle knob on the header which I haven’t been able to identify. The oil control valve is right above it but I don’t think that’s related.
Now that the area is cleaned I’ll monitor it to see if I can pin point the leak.
2008 4Runner
Old 03-08-2022, 08:31 PM #4
Thats the exact spot known for causing a leak. mating surfaces connect right there from the head to the engine, as well as from the timing cover. So theirs certain spots in there that need a little extra sealant. Seems common around 120k+ miles that its showing up, from other threads i've read and the mileage comparison they have. Not a hard job as almost everything is easy access, but just time consuming as you have to move all the components out of the way. P/S pump, a/c condensor, fan, oil housing, etc.
Old 03-09-2022, 01:30 PM #5
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
I'm no expert but I believe that is some sort of case vent. It looks like oil blowby from excess pressure or something you would see around your PCV and not an actual leak. I would have to assume that is normal/expected as there is visual evidence around my 08 V6 as well.
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 11-18-2022, 11:17 AM #6
richieca richieca is offline
richieca is on a distinguished road
Yup thats a timing cover leak common on all 2GR V6 Toyota engines.
richieca is offline   Reply With QuoteReply With Quote
Old 01-20-2023, 12:55 AM #7
Run4Evr's Avatar
Run4Evr Run4Evr is offline
Real Name: Mongy
Run4Evr is on a distinguished road
Run4Evr's Avatar
Real Name: Mongy
any updates on this? i noticed the same on mines tonight.
Run4Evr is offline   Reply With QuoteReply With Quote
Old 01-20-2023, 01:12 PM #8
It’s leaking from your timing cover, that’s the most common spot on our engines to leak. Have to pull everything off the front, alternator, fan, etc., valve covers, and a lot of the intake has to be taken out. It’s not a hard job just a pita with all the shit you have to take off.
bolt , engine , information , oil , spot
Timing cover leak = first trip to dealer cmills 5th gen T4Rs 110 12-01-2022 01:50 PM
Timing cover leak SKINUM 5th gen T4Rs 22 11-07-2022 10:45 PM
Need help with leak identification, possibly valve cover gaskets? psyduck 3rd gen T4Rs 7 07-15-2021 05:47 PM
Timing cover leak TSB follow up - how's it holding up? StateofDenver 4th Gen T4Rs 4 03-12-2019 12:59 PM
Timing Chain Cover Leak ? act1v3x 4th Gen T4Rs 8 11-19-2018 09:44 PM
