Old 03-09-2022, 08:09 PM #1
BigMike18 BigMike18 is offline
Real Name: Mikey Barger
BigMike18 is on a distinguished road
Pulley Misaligned, Making Squeal?
Replaced my power steering pump as it was giving me problems and I finished it off. Went well and was able to continue on but I got this serpentine belt squeal now. I can tell it’s from this power steering pulley because everything else was fine before, and I can visually see it doing some different movement.
It’s misaligned ever so slightly backwards (or not in flat/straight line with all the other pulleys). Not sure how to fix this? Loosen the bolt holding the pulley and guide it forwards? (90% sure that probably won’t work) Get a new pulley itself? Reinstall pump? (Trying to avoid this one). Any ideas would be great, havent dealt with this before.
-Thanks, Mike.
Pulley Misaligned, Making Squeal?-018a9acf-865f-415d-9a16-799988cb841c-jpeg  Pulley Misaligned, Making Squeal?-be8f3b02-dd9f-480a-b1f3-fb208a93f65a-jpg
BigMike18 is offline   Reply With QuoteReply With Quote
Old 03-10-2022, 09:24 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
In the sequence you mention, recheck your work, maybe pulley not fully seated or whatever.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 03-10-2022, 09:44 AM #3
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
most squeals can be fixed with a simple retightening of the pulley or tensioner
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
it’s , misaligned , pulley , pump , steering
Question - Misaligned Door on a 18 ORP...? rodralig 5th gen T4Rs 3 10-18-2021 12:50 PM
02 front door window seal misaligned money_pit 3rd gen T4Rs 5 04-30-2014 09:59 PM
Belt / pulley squeal, VSC, TRAC, Check engine light on after offroad. volcom440 4th Gen T4Rs 14 03-15-2014 02:34 PM
Is it possible that my wheels got misaligned after a tire rotation. hyperthread 4th Gen T4Rs 4 11-27-2013 03:25 PM
Pulley or Fan Squeal bryancos Maintenance/Detailing 4 03-23-2005 02:23 PM
