Old 04-02-2022, 09:33 AM #31
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
i was letting him know the memories i had with his grandfather, as my dad at one point for income started fixing cars in the garage and since i was the older brother i was forced to help. i remember being so annoyed that i had to help all the time, now that i'm older i'm glad my dad was rough on me to learn all that stuff cause its so helpful to have that confidence to fix something.
Told my son for right now it will all seem like gibberish but the more you work on cars, things will start to piece together. my kiddo saw the swap from v8 4runner to now the v6 and like i told him, i have no clue how to work on them. But i'm not scared to with what i've learned throughout the years. a manual, some time, and alot of cursing and it'll get done.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 04-03-2022, 10:59 AM #32
So between last night and this morning we finished putting the heads on, valve covers, lower oil pan, and smaller oil pan. Engine is now sealed up, gonna put the motor mounts and than time to put it back in.
Engine build-image1-copy-3-jpg  Engine build-image2-copy-2-jpeg  Engine build-image0-copy-3-jpg
Old 04-04-2022, 05:17 PM #33
MikeinNH67's Avatar
MikeinNH67's Avatar
Can't beat father/son (or daughter) time wrenching on stuff. Don't forget to show him the financial side of this project. This is how life lessons are built.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 04-10-2022, 09:20 PM #34
Today once the kiddo got home at 5pm, persisted to connect the chains and mount this bad boy in. once one dowel was lined up was able to wiggle the other one into place, once the motor was level with it. Actually had more trouble with the motor mounts than lining up the tranny. probably took a good 20 mins to line the tranny up. i had the boy tighten all the bolts for the tranny and we continued on with the motor mount. took them both off and lined both of them assembled together and than put all the bolts on. So far everything lined up good, Wiring and hoses and she'll be all done. i say by this weekend as i want the boy to finish all the work, so far hes done most of the major work.
Engine build-image0-jpg  Engine build-image1-jpeg  Engine build-image2-jpeg
Old 04-14-2022, 10:33 AM #35
Nothing like having to pull the engine again, because you put the drive plate on backwards. ahhhhhh.
Engine build-lift-jpg
Old 04-14-2022, 10:42 AM #36
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Noooooooo!
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 08:26 PM #37
Had it out and swapped the plate in like 25 mins, putting it back in took a little longer. Everything lined up and bolted up good, put the starter in while I was messing with that corner.
Have the intake, wiring, and drive components left to install. Saturday I’m off so I’ll probably finish putting everything back in and let the boy start it up Sunday since he put the engine together.
Old 04-15-2022, 08:39 AM #38
Eddie Haskell Eddie Haskell is offline
Eddie Haskell is on a distinguished road
Record it and let us all see!
Eddie Haskell is offline   Reply With QuoteReply With Quote
Old 04-15-2022, 06:14 PM #39
SurferUK's Avatar
SurferUK's Avatar
Glad the swap was quick - agreed record that first start!
Old 04-19-2022, 09:26 AM #40
Went to start it up this morning and having issues getting the starter to engage, just get a click. Checked the grounds
Two behind the heads
One pass side body by ps reservoir
One drivers side body lower under battery
The bracket that bolts to the alternator
And the big ass one to the block.
Took the starter to advance and spun right up, put it back in and still just click.
Charged the battery too just in case
abuse , good , heads , previous , redid
Engine loud metallic engine rattle @1800 rpm after sitting in traffic protist 3rd gen T4Rs 5 08-17-2019 08:04 PM
Intermittent vehicle/engine shake and vibration with check engine light present lloydster 3rd gen T4Rs 26 09-26-2017 11:58 AM
my 92 budget build. engine swap and front end swap? bhenry92 Classic T4Rs 4 08-06-2013 05:42 PM
Engine Rebuild/Supercharger 7th Injector/pulley/meth build questions 05SVRACER 3rd gen T4Rs 10 06-21-2013 09:38 PM
performance engine build, need some help the4runner Classic T4Rs 5 03-21-2012 09:33 PM
