09-03-2007, 08:51 AM
Rear Hatch struts to strong
I have an 07, and my Fiance has a really hard time closing the hatch, it is just hard for her to pull down. Has anyone changed the stuts out to lighter ones? I realize they are strong because when the glass is down it balances out the weight, but she never puts the glass down with the hatch up, so she struggles every time to put it down. So if you changed them, what did you use? I already searched and didnt come up with much...thanks for the help guys!
09-03-2007, 09:13 AM
I doubt if anyone has actually changed the struts on a 4th gen runner
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
09-03-2007, 10:01 AM
i dont think her height is the issue. I think it is strength, she is a hair taller then me (~5'9"), I am about ~5'8". Even I struggle with it sometime....
09-03-2007, 11:37 AM
Does she use the strap to pull down? I noticed its much easier that way.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
09-03-2007, 12:56 PM
i wish toyota should put the automatic lift gate setup in all their SUV, regardless of which brand (lexus, toyota), it doesn't mean if the SUV is a few thousand dollars less shouldn't deserve one. a 4R limited is about same price as RX but RX has it 4R doesn't. just a thought.
-Eric
07 V8 Limited 4X4
Wife said: "That's not your Runner!!!!!" I said: "WHAT???????"
09-03-2007, 02:17 PM
Ya she uses the strap.....I may try to lube it up or something first....
09-03-2007, 02:18 PM
im not sure if i'm thinking of the same thing or not but our 99 Landcruiser had a split hatch where the top half would flip up and the botton half would flip down like on a pickup truck, i thought this was far easier than the 4R's but ofcourse it didn't have the ability to lower the rear window.
09-03-2007, 02:48 PM
either you got a bad set of struts or you guys need to start lifting weights.
2006 4wd v8 sport, functional hood scoop, OME 896 886 and OME shocks, icon billet UCA, icon rear UCA, two frogs racing rear lower control arms, spidertraxx, in channel window visor, volant intake, magnaflow catback, dual battery, HID roof lights, PIAA back up lights
09-03-2007, 02:53 PM
Super Moderator
Super Moderator
Personally, I find that using the strap is awkward. Instead, I use the edge of the tailgate -- it's easily within reach and you get better leverage. Just be careful not to scratch the tailgate with jewelry.
2003 SR5 V6 4WD Titanium with cladding
09-03-2007, 03:10 PM
If it's a problem, you can have her roll down the rear window first and then close it once she has the liftgate closed. It's a lot easier to close the hatch with the window down.
2003 4Runner SR5 V6 4x2 - Pacific Blue Metallic/Taupe Leather
09-03-2007, 03:18 PM
Both ways are a pain! I'm going to try it with the window down, it sounds like it has possibilities.
Larry
09-03-2007, 06:14 PM
My wife and I are both about 5'8" and we dont have any trouble with it. Sure it's a bit stout at the breakover point from where you stop pulling and have to switch to pushing to close it, but it's not that bad. You guys need to eat your wheaties LOL. Or put a winch behind the back seat and hook it to the strap!!!!
2006 Toyota 4Runner SR5
2000 Dodge Ram 1500
1996 Dodge Ram 1500
1989 Honda Accord LXI
1968 Dodge Charger R/T
1968 Chevrolet C10 Stepside
09-03-2007, 06:18 PM
Gas struts (also known as gas stays) are strong at normal temperatures because the OEMs size these to maintain gate open down to -40^. The nitrogen gas charge pressure follows ideal gas law properties.
Over the years this charge slowly leaks such that eventually you will have to replace the struts if you keep the vehicle long enough.
The gate is indeed hard to close but Toyota has designed the gate's counterbalance with almost no over-center gravity moment (requiring the electric cinching latch to engage primary latching) and this all makes for a very easy opening gate -- don't you agree?
Clarke
'05 4x2
09-03-2007, 07:20 PM
Ya this is what I told her to do, but she always forgets.....
09-03-2007, 11:04 PM
Super Moderator
Super Moderator
The new Highlander's got it as an option. But I'm with you, if Toyota is going to offer that on the Sienna, the next 4Runner should have it. Since this first showed up on MY2004 RX330s and Siennas.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
