Old 10-28-2014, 01:19 AM #1
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
DIY Bluetooth/Voice Command steering wheel button install (pics)........for REAL
OK, this subject has been covered ad nauseum, however many complain of the lack of pictures. It's really quite simple. Hope this helps anyone.
Purpose: If you added an OEM NAV, like I did, this will enable BT commands for the headunit on the steering wheel, just like it came from the factory. If you have an aftermarket HU, this will also help you, however you guys will need a PAC unit and will need to program it. Unfortunately I don't have any knowledge of that.
Note: You will notice both my right and left side buttons are not installed initially for this writeup. I previously took them off. In any event, it shouldn't matter.
1) Disconnect the negative terminal of your battery. You will need a 10mm socket. This is to minimize (eliminate) any chance of the airbag exploding in your face. Expert installers usually don't, but most of us are novices, so.........
2) On either side of the steering wheel, there are covers that pop out. Use a flathead and gently pop them off. After that, you will see a Torx 30 head, loosen this (but don't completely take it off). Loosening it (screw) will loosen the airbag off of the steering wheel. Repeat for the other side.
3) Grab the bottom part of your airbag and push up and/or outward and the bag will come off. That's it, the bag is held in place by only these 2 torx screws. You don't need to disconnect it, just set it aside.
4) Set it aside, or better stated: place it on top of the steering wheel. Again, no need to uninstall the airbag connectors.
5) Here you will see a philips screw toward the top of the volume/station/mode button assembly. Take it off and set it aside. The left side buttons (volume/station/mode) are further attached to the steering wheel via a connector (white) at the rear of the assembly. Unlatch it. Your button assembly is now free. Same goes for the blank over on the right side. However, there will be no connector to unlatch.
6) Install your buttons and ribbon cable (Right Module/bluetooth buttons #84244-35030-B0 and Ribbon Cable #84204-58010). The ribbon cable is what attaches your BT buttons to the left side button assembly. It is used to transport signals from the left side button to the right side module when any button on the BT side is pressed. Be careful not to rip it or its game over.
7) Note that at the end of the ribbon cables are the attachment ports. You will notice the word "PULL" on the side of the port. I noticed you can push it in , but I haven't confirmed if it's to lock it into place or what.
lock or unlock?
8) Anyway, gently snap it into place. It only goes in one way. You will also notice a whitish/clear plastic tabs with holes in the ribbon cable assembly. This is to hold the ribbon cable in place and prevent it from completely folding (damage).
9) Take hold of the plastic and bend it SLIGHTLY so it fits into the button assembly. You will notice two "prongs" sticking out. Ok, these prongs are to go through the holes, like so:
10) Turn the assembly around and install it into the steering wheel. At the halfway point of the ribbon cable, you will notice a clip. Now look behind toward the steering wheel and you will notice where this clip is supposed to "clip" onto.
11) Clip on!! Repeat for the other side: (please note this ribbon is ripped, I used it to "practice" installing the new one)
12) Reinstall the screws on both sides so they both button assemblies are firmly installed.
13) Get your airbag and place in where it should go. Make sure it's aligned and go to either end where you loosened those torx screws and tighten! Next reinstall the plastic steering wheel covers (snap on) and your done!
14) Reconnect your battery, let your NAV boot up. When you touch any BT button, you should get a screen similar to this one:
At night, they will light up like so:
Like I mentioned before, this is very easy. Especially for those with aftermarket HU (you will need a PAC kit and program it) or an OEM NAV unit. Other BT enabled HU (OEM Toyota) will also benefit from this add on.
EDIT: fixed the photos, sorry. Also, if you add these buttons, if you get an Android head unit, you can totally use them without any PAC kit.
CookieRoe is offline   Reply With QuoteReply With Quote
Old 10-28-2014, 09:10 AM #2
Topher88 Topher88 is offline
Topher88 is on a distinguished road
I have an 05 with factory nab. Wil this work on mine? I thought I read somewhere where only the later 06+ navs are capable of this...
Topher88 is offline   Reply With QuoteReply With Quote
Old 10-28-2014, 12:25 PM #3
YetiX's Avatar
YetiX YetiX is offline
Real Name: Scott
YetiX has a spectacular aura about YetiX has a spectacular aura about YetiX has a spectacular aura about
YetiX's Avatar
Real Name: Scott
Having just done this twice in the past three days, I believe the airbag bolts are Torx 30. Otherwise, good write up!
-Semper Fi-
2006 4Runner Sport Edition 4WD V6/Suspension/Armor/Lights/Wheels and tires/Drawers/Camping things/Surfboards/Rhodesian Ridgebacks . . .
BUILD AND ADVENTURE THREAD
YetiX is offline   Reply With QuoteReply With Quote
Old 10-28-2014, 12:41 PM #4
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Thing is: '03 to (I think) '05 models that came with NAV did NOT come with bluetooth, so if your HU isn't BT ready, then this will not work. HOWEVER, you can easily swap your NAV to a newer one (E7008 or E7009 model) and this will work. Additional wiring will be required (microphone/etc)
Old 10-28-2014, 12:42 PM #5
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
My bad, corrected!!
Old 10-28-2014, 03:21 PM #6
acronin2 acronin2 is offline
Real Name: Lance
acronin2 is on a distinguished road
Real Name: Lance
Great write up! This is on my "to do" list
2004 Sport Titanium Metallic, Black WeatherTech Mats, J.A.'s Map Light Mod, 2014 Scion Pioneer Bespoke touchscreen w/ Back Up Camera, Arc Audio xdi805 amp, Handsfree phone/bluetooth steering wheel controls, 06-09 OEM LED tail lights, Interior LED Swap, Gentex 177 AutoDimming Mirror w/ Amber Compass, Sunvisor GPS mod, Avitol 4003 Remote Start w/ factory keyfob, J.A.'s DRL Mod, Back Window Up Hack, OEM 115v AC inverter install, Smokers Kit
acronin2 is offline   Reply With QuoteReply With Quote
Old 10-28-2014, 03:27 PM #7
Thanks you sir
Old 10-29-2014, 12:40 AM #8
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Thanks you sir
Old 10-29-2014, 02:32 AM #9
madeinhb madeinhb is offline
madeinhb is on a distinguished road
My stereo controls don't light up. Are there replacement bulbs for these or do I have to replace whole module?
madeinhb is offline   Reply With QuoteReply With Quote
Old 10-29-2014, 10:29 AM #10
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Those are leds that are soldered onto the circuit board. @emelianenkov : right? Give him a shout out and he can take care of your problem (reLED). No need to replace the whole module. Unless of course it doesn't work (volume, station, mode), then yes, get another one.
Old 11-06-2014, 10:09 PM #11
yosh2000 yosh2000 is offline
yosh2000 is on a distinguished road
those controls are LEDs, not bulbs. i actually changed cookieroe's LEDs in his NAV and im in denver. give me a shout and i can maybe help you out...
05 4runner SR5 4x4 v8 : Build thread - Hailed totaled
17 Tundra SR5 crewmax 4x4 v8
yosh2000 is offline   Reply With QuoteReply With Quote
Old 11-09-2014, 10:41 AM #12
gshadow325 gshadow325 is offline
gshadow325 will become famous soon enough
My bad, corrected!!
i spy a piano steering wheel
You corrected me on my DIy for steering wheel replacement too
gshadow325 is offline   Reply With QuoteReply With Quote
Old 11-10-2014, 03:23 PM #13
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Yes, didn't mean to sound like a d***. Being corrected is cool, so long as the shared info is correct, no problems
I love my steering wheel.
Old 11-10-2014, 03:26 PM #14
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
I love how your steering wheel magically changes in the last picture
Old 11-10-2014, 03:27 PM #15
Real Name: Chris
Real Name: Chris
Definitely hit up Josh, he's a great dude and will take care of you
[Rewrite] How to install phone control and voice command switches honda_nos 4th Gen T4Rs 70 12-01-2018 03:12 PM
Voice Command List for NAV jimmy2x Engines / Suspension / Wheels / Tires / Audio / Accessories 3 11-22-2008 12:55 AM
Voice Command Question ahearn Engines / Suspension / Wheels / Tires / Audio / Accessories 4 11-15-2006 12:45 PM
Latest Mod: Voice Command factory steering wheel switch gregtay Engines / Suspension / Wheels / Tires / Audio / Accessories 36 09-25-2006 05:10 PM
Voice Command for 05 OEM Nav. Koz Engines / Suspension / Wheels / Tires / Audio / Accessories 11 06-23-2006 05:45 PM
