Old 03-31-2022, 11:27 AM #1
sport2004's Avatar
sport2004 sport2004 is offline
Real Name: James
sport2004 is on a distinguished road
sport2004's Avatar
Real Name: James
Tires!
Hi Guys - I'm running Michelin stock size 265/65-R17, fantastic tires, but they are now 10 years old. The big shops won't even fix them due to code/regulations, etc. I found a small shop that pulled/patched a nail.
With replacements, what are the cons of moving bigger to 265/70-R17's...? I'm looking at A/T's in Goodyear, Goodrich or Falken. From what I've read here and elsewhere, there is very little chance of rubbing.
Thoughts? Any insight appreciated, thanks!
P.S. I'm in the Midwest, this is my DD, and I drive in everything.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
sport2004 is offline   Reply With QuoteReply With Quote
Old 03-31-2022, 11:43 AM #2
BadTrainDriver BadTrainDriver is offline
BadTrainDriver will become famous soon enough BadTrainDriver will become famous soon enough
Falken Wildpeak AT3W all day long!
BadTrainDriver is offline   Reply With QuoteReply With Quote
Old 03-31-2022, 03:25 PM #3
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
The only con I can think of is possibly lower mpg. Of course there's some variables such as tread pattern and tire weight. Stick with a light, mild tread AT and you may not see any difference. I would recommend to buy 5 so the spare matches.
I like the Toyo AT3, BFG KO2 and have lately been looking at the Firestone XT.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 03-31-2022, 03:36 PM #4
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Thanks, was thinking mileage, noise and ride. Just looked at this from Michelin, LTX A/T 2, in stock size. The marketing suggests something pretty close to your recommendation:
Michelin Comfort Control Technology reduces road noise and vibrations
Strong, off-road durability helps extend the tire's life by at least 35% longer than leading competitors, according to Michelin
Get reliable all-terrain traction on gravel from Michelin's MaxTouch Construction that produces a wider, more aggressive contact patch
Regards, sport2004
Old 03-31-2022, 03:37 PM #5
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Thanks.
Regards, sport2004
Old 03-31-2022, 03:40 PM #6
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Also, a lot of choices are on back order right now.
Regards, sport2004
Old 03-31-2022, 03:50 PM #7
The Michelins AT2 is another good choice for a daily driver with some light trail use. Those tires came stock on my Tundra and other than undersized (in my opinion) they were good tires. Unfortunately, a lot of tires are on backorder but with some shopping around, you may get lucky.
Old 03-31-2022, 03:54 PM #8
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Thanks!
Regards, sport2004
Old 03-31-2022, 03:55 PM #9
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
I suppose it has happened, but has anyone ever said, "Jeez I hate these Michelins I just bought...?"
Regards, sport2004
Old 03-31-2022, 04:09 PM #10
MikeinNH67's Avatar
MikeinNH67's Avatar
Ha, not in my house. Other brands for sure.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-31-2022, 04:23 PM #11
I'm generally a die hard Michelin fan...I just wish the AT2 was a little more aggressive looking. It's due for a redesign...
Old 03-31-2022, 04:28 PM #12
Same here. I wish they were more aggressive but then they become like some of the other tires out there, loud, heavy, fast wear, etc. With today's gas prices, I've considered them lately for the tundra, just in a little taller size.
Old 03-31-2022, 10:23 PM #13
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
Possible rubbing and worse MPG with larger tires. I second the suggestion to get 5. You can do a 5 tire rotation too and get some more miles out of the set. I really like my Cooper AT3 4S in one size bigger than stock. If you go to a more aggressive tread pattern you may notice a difference in road noise also.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Unner is offline   Reply With QuoteReply With Quote
Old 04-01-2022, 06:26 PM #14
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
I had my LTX2, the second set, for about a year and they started to dry rot, cracking all around the treads and sidewalls. Michelin gave me the middle finger on warranty for it.
Coincidentally, I bought said set of LTX2's to replace the previous Michelin LTX set which had dry rotted and cracked terribly. I figured it was a one-off and they were around 6 years old at the time, kinda seemed okay in the Alberta sun to have some cracking... and regardless, these LTX2's are new, everyone's raving about them, Michelin makes great tires.
Anyway, Michelin telling me to go find salt to pound really pissed me off when I asked about a warranty claim for the dry rot. Kal-Tire submitted a warranty claim request and it was denied. So you couldn't pay me to run their shitty tires on my rig. I'd rather have retreads. I had to drive around on tires that looked 30 years old for 5 years to justify replacing them, for the $2000 bill. So Michelin can get f*cked.
I don't think they're worth the money, they just spend more on advertising.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 04-02-2022, 05:15 PM #15
idahonick idahonick is offline
idahonick is on a distinguished road
Same experiance and no more Michelin's for me
I had always had good luck with Michelin tires, but the last 2 sets on my 2003 Limited have developed cracks. I currently have X Radial LT2's that are cracking on the sidewalls and tread to the point that inner material is protruding through. I don't drive the 4runner often now, and definitely won't be driving it again until they are replaced. This started with about 5 years on the tires and has continued to worsen. Michelin wasn't interested in hearing from me, other than to suggest that I get a new set of Michelin tires.
In contrast, I have Bridgestone Revo II's of the same age on my truck and not a sign of cracking or dry rot on them. The truck has spent its life parked outside. The 4runner is always garaged.
I had an LS430 with Michelin Pilot Sports and though there was no cracking, they were actually louder than the 4runner tires.
My wife's GX460 came with Michelin Latitudes, and you can bet I'll be keeping a close eye on them.
2003 Limited V8
2018 GX460
idahonick is offline   Reply With QuoteReply With Quote
appreciated , bigger , cons , moving , tires
FS:TOYO open county 295-70-R17 tires/Trail edition wheels w/general 265 tires 97supratt For Sale: Suspension/Wheels/Tires 17 01-07-2020 03:09 PM
Tires tires tires Maxxis Trepador VS Goodyear MTR KaliKid General Discussions 3 11-18-2015 11:44 AM
2015 Trail edition 18"tires and Cooper Tires rubbing xtreme-24 5th gen T4Rs 5 11-29-2014 11:11 AM
Suggestions on snow tires or all terrain tires for a 2002 2WD 4Runner Limited? sienna221 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 11-14-2014 03:39 PM
Upgrade Tires, CV Boots are now leaking after upgrading tires and need advice. AZ4runner08 4th Gen T4Rs 20 02-16-2014 06:21 PM
