Old 04-13-2022, 06:10 PM #16
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
Originally Posted by Schnalan View Post
Sounds very similar to my issue except I’ve got a P0430 code to go along with it. Just replaced both downstream O2 sensors and the issue persists. Seems like it all started after a pretty hard bump on some rocks, so kinda thinking it may be electrical. Symptoms below:
If i go heavy on the throttle (in park, neutral, or in gear) it feels like it’s choking. Like a stutter, but its not always around the shifting so not confident it’s trans/torque converter related. Always happens right around 2800-3000 rpm.
If I jump in and turn the key right away it’ll crank, start up, and die almost immediately. But if I flip the key to on and wait like 10 seconds before cranking, it starts up and stays running. It also randomly stalls while I’m driving, but I just toss it in neutral and it starts right back up.
Cleaned the MAF, TB, and checked all the fuses to make sure they are in there nice and tight. Checked connections on fuel pump and battery terminals. Thinking maybe a crankshaft position sensor or fuel pump but I’m kinda lost at this point. Don’t want to keep throwing money at non-issues
Yep, my truck did all of these things, with the exception of the code. It was also totally random, never related to weather or road condition (uphill, downhill, turning left or right, etc).
It just kinda did batsh*t crazy things randomly, and other times it'd be fine.
Replacing the TB solved all of it. I used a Tundra TB, I'm unaware if there's a particular difference between that and the 4Runner TB. I was about to go down the route of replacing the O2 sensors but came across that other dude who had the TB replaced, solving his issues.
Re-reading my previous post, I don't know why I said it didn't bog under accel, I recall one day in Surrey, I had no ability to apply power; like, the engine would produce just enough power to move the truck forward at constant speed and nothing more. Thankfully it started that shit after I got off the highway, but it was pretty scary because it could have happened 5 minutes before and I'd have been in REAL trouble.
I arrived, shut it off, said a prayer to the God Boost, and his disciples, Intake, Compression, Combustion, and Exhaust, so that when I return to the truck I can make it all the way home. And the gods blessed the 2UZ, she fired up and got me back home.
I swear I was a few microns from using a Molotov Cocktail to fix the damn thing.
The first sign of problems was it stalling on me during a snow storm turning left in a neighbourhood in winter of 2014. 2 years later, it did it again in the dead heat of summer. Then around ~2018 or so, it did the above mentioned shit every other week.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 11:02 PM #17
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
Originally Posted by Lucas606 View Post
It’s an aftermarket MAF. Old one was throwing codes so I replaced it about a year ago. No codes since then. The timing belt was replaced at 100k miles and then again because it was wearing quickly. The current belt that’s on it is beginning to squeak when it rains so that’s a pain. Plugged in my scanner to check for codes but there’s nothing pending. The short term fuel trims seem to be everywhere though for both banks. Short term for B1 fluctuates anywhere from -7.8 to 3.9 at idle, and short term for B2 -2.3 to 3.1
I don’t care for aftermarket MAFs and TBs (and numerous other parts) due to issues I’ve had on various vehicles with them. It does sound more like the TB in your case.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 04-15-2022, 08:29 AM #18
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
why are people using tundra throttle bodies?
rwh963 is offline   Reply With QuoteReply With Quote
Old 04-15-2022, 10:16 PM #19
Schnalan Schnalan is offline
Schnalan is on a distinguished road
Sounds like I need to try replacing the TB, I hit a bump and that seemed to cause the issue which sounds similar to the story referenced.
appreciate the insight
Schnalan is offline   Reply With QuoteReply With Quote
Old 04-16-2022, 11:28 AM #20
4-Funner 4-Funner is offline
4-Funner is on a distinguished road
Probably because there's many times the number of these exact same V8s that came in Tundras than there were in 4Runners.
2007 Toyota 4Runner Limited V8
4-Funner is offline   Reply With QuoteReply With Quote
Old 04-16-2022, 08:13 PM #21
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I think I still have my '04 Throttle Body sitting in a box somewhere...
It works perfectly fine, the freeze plug on the top was seeping coolant so I just sealed it in FIPG and kept it in case I ever needed an extra...
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 04:23 PM #22
Lucas606's Avatar
Lucas606 Lucas606 is offline
Lucas606 is on a distinguished road
Lucas606's Avatar
Originally Posted by Keros View Post
My truck didn't do the bogging under accel, but it did, on occasion, search for idle while stopped. It would also quit on me... one time, it quit atleast a dozen times leaving the parking lot of a mall. Not its best moment.
When you replaced the throttle body did you have to do a relearn at all? Or was it running fine after installing it?
Lucas606 is offline   Reply With QuoteReply With Quote
Old 04-20-2022, 07:35 PM #23
I think the shop had disconnected the battery long enough to have to relearn the fuel curves. But it was a long time ago, so I can't say for sure.
In any case, it ran perfectly after changing the TB. All the shenanigans it used to do were immediately gone... She just fired up and ran.
2005 V8 Limited
check , i’m , i’ve , it’s , start
Unknown Oil Leak and Starter Issue SCHUNTER1969 3rd gen T4Rs 20 11-15-2020 09:54 AM
Using Toyota ATF Type T-IV with unknown current fluid JWaldz 3rd gen T4Rs 61 02-25-2020 09:09 AM
Need help! Unknown issue causing excessive tire wear! Rudy97 3rd gen T4Rs 16 06-03-2013 02:41 PM
2008 4Runner - Possible Transmission Issue? 1946 Maintenance/Detailing 3 11-30-2009 08:21 PM
