Old 04-01-2022, 10:15 PM #1
Lucas606's Avatar
Lucas606 Lucas606 is offline
Lucas606 is on a distinguished road
Lucas606's Avatar
2008 Toyota 4Runner V8 unknown issue
Hey all
I’m hope you guys can help me figure this out. It has been plaguing my 4Runner for a while now and it’s driving me nuts. It has just over 154k miles and it bogs under heavy acceleration as well as while when it’s in neutral and you press hard on the gas. Not only this but it’s even searching for idle. I’ve only had this happen once and it stopped searching when Put my foot on the throttle. I’ve also had to stall on me once while accelerating from a stop, and once while coming to a stop. The strange thing is that it starts right back up like nothing ever happened. Other than this it drives completely fine. I would like to mention is that it has Doug throuley headers but this issue began well after they were installed.
I’ve tried some troublshooting myself and this is what I’ve noticed. I don’t believe this is related but it’s low on coolant after being filled up not too long ago. Maybe coolants getting into a place that it shouldn’t be? I also went to remote start it a few days back and it refused to start. The engine would turn but not start for some reason. The second time I used the key and same thing. It would just turn and not start. It eventually started on the third try with the key. Also no check engine lights. I have no idea what’s causing this and my local mechanic can’t seem to figure this out either and it’s driving me insane. I’ve been told to check for spark, air, and fuel but becides that I don’t know what else to check for I’m hoping that you guys can shed some light on the situation and provide some input.
I tried uploading the files but it would let me. Here are the Imgur links.
Searching for idle while parked - Album on Imgur
Imgur: The magic of the Internet
Edit:throttle body was replaced today. Truck still bogs and idle fluctuates constantly while the AC is on
Lucas606 is offline   Reply With QuoteReply With Quote
Old 04-02-2022, 01:41 AM #2
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
My truck didn't do the bogging under accel, but it did, on occasion, search for idle while stopped. It would also quit on me... one time, it quit atleast a dozen times leaving the parking lot of a mall. Not its best moment.
Replaced the throttle body with a low-milage unit from a Tundra, no problems since.
There were no diagnostics that could isolate the issue. I read a thread somewhere about a guy who had his truck quit on him when he hit a bump, and his mechanic suggested replacing the TB, solved the issue. Having no other recourse, I did the same. Miraculously, it was my issue.
Simply that it seems you've got nothing else to go on, it might be worth a try (mostly 'cuz it's cheap and easy if you can find a TB). I got my new TB for about $100 from a wrecker.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 04-02-2022, 10:22 AM #3
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
Has it been scanned for codes, specifically looking for "pending" codes that won't set a CEL? Has the MAF ever been cleaned or replaced? Same for the throttle body.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 04-02-2022, 06:28 PM #4
Lucas606's Avatar
Lucas606's Avatar
It has not been scanned for codes recently, but the last time it was scanned there was nothing pending. The MAF has been replaced with a new one but the throttle body is original from the factory. It has not been cleaned
Old 04-02-2022, 06:40 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Is the new MAF sensor OEM or aftermarket?
2004 Limited V8
Old 04-03-2022, 11:22 AM #6
New or aftermarket MAF?
Has the timing belt ever been replaced? The crank sensor wiring runs close to the pulleys and after a timing belt, sometimes the clips don't hold right causing the wiring to rub through. I've read about another member on here with similar issues and that was the cause.
I would also recommend to check all the vehicle electrical grounds and connectors for signs of corrosion, specifically the wiring at the front of the engine and underneath the fuse box. Might as well make sure all the relays and fuses are seated correctly.
Old 04-04-2022, 10:22 AM #7
Will_M Will_M is offline
Will_M is on a distinguished road
MAF or clean throttle body
Will_M is offline   Reply With QuoteReply With Quote
Old 04-11-2022, 02:53 PM #8
Lucas606's Avatar
Lucas606's Avatar
It’s an aftermarket MAF. Old one was throwing codes so I replaced it about a year ago. No codes since then. The timing belt was replaced at 100k miles and then again because it was wearing quickly. The current belt that’s on it is beginning to squeak when it rains so that’s a pain. Plugged in my scanner to check for codes but there’s nothing pending. The short term fuel trims seem to be everywhere though for both banks. Short term for B1 fluctuates anywhere from -7.8 to 3.9 at idle, and short term for B2 -2.3 to 3.1
Old 04-11-2022, 03:07 PM #9
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
This sounds like you mean the auxiliary drive belt for PAS, AC, alternator etc?
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 04-11-2022, 04:31 PM #10
Schnalan Schnalan is offline
Schnalan is on a distinguished road
Sounds very similar to my issue except I’ve got a P0430 code to go along with it. Just replaced both downstream O2 sensors and the issue persists. Seems like it all started after a pretty hard bump on some rocks, so kinda thinking it may be electrical. Symptoms below:
If i go heavy on the throttle (in park, neutral, or in gear) it feels like it’s choking. Like a stutter, but its not always around the shifting so not confident it’s trans/torque converter related. Always happens right around 2800-3000 rpm.
If I jump in and turn the key right away it’ll crank, start up, and die almost immediately. But if I flip the key to on and wait like 10 seconds before cranking, it starts up and stays running. It also randomly stalls while I’m driving, but I just toss it in neutral and it starts right back up.
Cleaned the MAF, TB, and checked all the fuses to make sure they are in there nice and tight. Checked connections on fuel pump and battery terminals. Thinking maybe a crankshaft position sensor or fuel pump but I’m kinda lost at this point. Don’t want to keep throwing money at non-issues
Schnalan is offline   Reply With QuoteReply With Quote
Old 04-11-2022, 04:42 PM #11
Lucas606's Avatar
Lucas606's Avatar
Yeah that’s the one! I always get them confused 😅
Old 04-11-2022, 05:02 PM #12
Lucas606's Avatar
Lucas606's Avatar
Did some poking around in the engine bay and it turns out the throttle body is making some very loud buzzing. I took off the intake tube and the plate looks visually dirty, but what’s odd is that the throttle plate isn’t sitting fully closed and had some play in it possibly? This can totally be nothing But it’s the only thing that I can notice. Everything else seems fine. I purchased some cleaner earlier today so I’m hoping that helps.
Links to videos:
Imgur: Throttle body buzzing
Imgur: Play in throttle plate
Edit: dirty throttle body wasn’t the issue
Old 04-11-2022, 06:19 PM #13
SurferUK's Avatar
SurferUK's Avatar
Links to videos:
It's a balance of spending more money on diagnosis of both the whole vehicle and the throttle body, or just start with replacing the throttle body. It doesn't sound happy...as Keros said he just replaced it and it sorted his problem.
Old 04-11-2022, 06:53 PM #14
Lucas606's Avatar
Lucas606's Avatar
This is what I’m going to do next. I want to attempt to replace it myself but I believe I’d still have to do a throttle relearn. The OBD2 scanner that I currently have doesn’t have the option to do the relearn. I’ve read that disconnecting the batter could work so I guess I’ll give that a go
Old 04-11-2022, 07:09 PM #15
SurferUK's Avatar
SurferUK's Avatar
Let us know how you get on
check , i’m , i’ve , it’s , start
Unknown Oil Leak and Starter Issue SCHUNTER1969 3rd gen T4Rs 20 11-15-2020 09:54 AM
Using Toyota ATF Type T-IV with unknown current fluid JWaldz 3rd gen T4Rs 61 02-25-2020 09:09 AM
Need help! Unknown issue causing excessive tire wear! Rudy97 3rd gen T4Rs 16 06-03-2013 02:41 PM
2008 4Runner - Possible Transmission Issue? 1946 Maintenance/Detailing 3 11-30-2009 08:21 PM
