Old 04-04-2022, 08:15 PM #1
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
best method to disable the cruise control?
i'm dealing with a few issues, and a new one is some sort of throttle hesitation. i believe it happened after i tested the cruise for the first time ever (one owner 2007 4runner, cruise never used). cruise seemed to work normal, but now i have this issue. would like to take cruise out of the equation. best fuse/relay or other to disable it?
rwh963 is offline   Reply With QuoteReply With Quote
Old 04-05-2022, 10:27 AM #2
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
The 7.5 amp GAUGE fuse runs cruiser control. It's highly unlikely cruise control is causing any of your issues.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 04-06-2022, 08:33 AM #3
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
I don't see how cruise-control would affect your throttle, but: is there anything else that's acting up/not at all?
Maybe try this reset:
How To Reset The Throttle Position Sensor In A Toyota - Car, Truck And Vehicle How To Guides - Vehicle Freak
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 04-06-2022, 10:02 AM #4
Ripper238's Avatar
Ripper238's Avatar
The off button?
Only time I had this issue was bad fuel filter in a Dodge van I had.
Old 04-06-2022, 08:56 PM #5
Originally Posted by Ripper238 View Post
The off button?
off button, thats funny! i put in some concentrated techron. i looked in the fuse section, but couldn't locate the cruise. others have mentioned the throttle body, throttle pedal. i was wondering were the fuel filter is in this vehicle; i assume in the tank.
Old 04-07-2022, 11:26 AM #6
Ripper238's Avatar
Ripper238's Avatar
I hope its not the throttle body. Yes, on top of the fuel tank.
Old 04-18-2022, 04:49 PM #7
went through a tank w/techron: nothing to report
cleaned the MAF sensor: hesitation still present
cleaned the throttle body: maybe improvement
Old 04-19-2022, 07:49 AM #8
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
Our 4R's have a "drive by wire" system. Remove the throttle pedal unit and put a meter on the pedal outputs. Maybe the rheostat is gunked up or has a dead spot somewhere and is sending a bad signal?
Montego Murph is offline   Reply With QuoteReply With Quote
Old 07-13-2022, 07:29 AM #9
so, still experiencing chronic but unpredictable drop offs. happens locally and at highway speeds. it coincidentally occurred after that initial cruise test. just yesterday, i was on the highway and decided to test cruise. could not get it to engage. i tried repeatedly, but did not function. light showed up on the dash.
is this throttle pedal unit down near the gas pedal. need to look up location and any service that can be done to it.
Old 07-14-2022, 08:20 PM #10
more fun: i've been pulling the #3 fuse under the hood often because it turns off the blazing stop lights. i forgot to put it back in this morning. started up the car, couldn't shift. the shift lock had activated. i pushed it down, and could shift. noticed for the first time the ABS light has turned on. i went under the hood and replaced the fuse. the ABS light stayed on all day. all other symptoms the same.
wondering if starting the car without that fuse in tripped the shift lock and ABS warning light.
as you can see, the #3 fuse is also swimming with many of the issues i'm encountering. thoughts?
best method to disable the cruise control?-thumbnail-jpeg
Old 07-14-2022, 08:28 PM #11
weird, just look at that.
1) stop lights
2) shift control lock
3) ABS
4) TRAC
5) VSC
6) fuel injection (hesitations?)
7)trailerl lights (recent failure)
Old 07-15-2022, 04:58 AM #12
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
1) stop lights
3) ABS
4) TRAC
5) VSC
7)trail lights (recent failure)
I wonder if there has been a water leak into there. You would probably have to strip everything out as a top down look just shows you the fuse holders, and water would go right to the bottom.
Either that, or the outgoing cables from that fuseboard have been damaged somehow.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 07-15-2022, 08:16 AM #13
i'm hoping all of these issues can be tied to one origin point, and a relatively inexpensive one at that. also hoping it is not the ABS module, as that is not inexpensive.
that said, i have never noticed any odd wetness in the fuse box area. what i have experienced over the past few years is an unexplained damp carpet only on the front drivers side. never seen any wetness under the dash, or water dripping anywhere. i've attributed it to some sort of drainage misdirection. i don't believe there is any wiring or electronics under that area.
4runner , cruise , disable , normal , work
Dynamic Radar Cruise Control / Vehicle-to-Vehicle Distance Control Mode / PCS hunthorde General Discussions 2 03-16-2023 09:46 AM
Bull Bar + Dynamic Radar Cruise Control / Distance Control Mode / PCS hunthorde 5th gen T4Rs 1 04-29-2021 11:09 AM
Cruise control help Thefishguy77 3rd gen T4Rs 5 07-21-2017 01:50 PM
Cruise Control light doesn't come on and Cruise doesn't work. CZ Eddie 3rd gen T4Rs 8 12-15-2012 08:09 PM
Cruise Control?? Levinz11 Classic T4Rs 3 06-20-2011 10:22 AM
