Old 04-06-2022, 03:43 PM #16
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Your bumpy ride and awkward handling feeling is the upper JBA ball joints being maxed out past their normal articulation. The amount of lift you have is putting the UBJ's beyond their normal limits.
I did this exact same thing one time and my front suspension was pissed. Not to mention your front CV driveline angle is way too much.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 04-06-2022, 03:50 PM #17
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Looks like the inner cv boots dont like this lift either, spraying grease it looks like.
I just tossed that ZPC idea out there as most seem to miss this final little thing after a lift.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 04-11-2022, 12:36 PM #18
PedroV PedroV is offline
PedroV is on a distinguished road
Well, I took the lift spacers off the top of the strut, put the stock strut top cap in, and reduced the clip on the 5100's by one clip, to the third from bottom, and now the truck is too low. Wish there was an easier way to figure out how high the truck will be other than trial and error. I think I will do this one more time, and put the lift spacer back on. Crossing my fingers!
It does drive a lot better this way. Hoping I can get the look I want with a little more lift, and will still drive OK. The clip I put it on is supposed to be a 2" lift, but it sure doesn't seem like it is that much.
New UCA's/Tires/Lift, now drives like crap-4runner-jpg
PedroV is offline   Reply With QuoteReply With Quote
Old 04-12-2022, 10:43 AM #19
mjg514 mjg514 is offline
Real Name: Matt
mjg514 will become famous soon enough
Real Name: Matt
are you still running stock springs in the rear? if you move that front clip up again and the nose is once again a bit high, you could look at getting longer springs for the back.
2007 SR5 V6 4x4 / Front Suspension: OME 884/90021 + SPC UCA's / Rear Suspension: OME 895/60004 / Tires: 285/70r17 BFG K02's (C Load) / TRD Pro Wheels / Apex Overland Front Recovery Points / Desert Armor Ninja RTT / Outgear Solutions Low-Pro Crossbars
2017 TRD ORP / Watch this space....
mjg514 is offline   Reply With QuoteReply With Quote
Old 04-12-2022, 01:02 PM #20
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Its a 2:1 ratio on the front.
If you add a 1/4 inch thick spacer it will lift you 1/2 inch in height.
If you add a 1/2 inch spacer it will lift you 1 inch.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 04-12-2022, 01:20 PM #21
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
instead of ZPC, I just broke a wheel speed sensor and it solved my random traction control problems lol
y=mx+b is offline   Reply With QuoteReply With Quote
Old 04-12-2022, 01:22 PM #22
y=mx+b's Avatar
y=mx+b's Avatar
The more you lift, generally the worse the ride is going to be.
the front geometry is optimized for the LCAs to be about level, and when you lift, they angle downward. The more angle downward the LCAs have, the more they have to scrub outward on compression, following the radius to their mounting pivots on the frame.
Old 04-12-2022, 05:13 PM #23
I have an arb bumper with a warn 8274 winch mounted up front. I was playing games like you are now and I finally just ordered OME heavy front coils with their stiffest strut. This solved all my issues. arbusa website has a chart for this.
Your arb weight is the problem and you're not picking the correct solution by playing with struts, springs, and spacers that are not designed for that amount of weight up front.
nothing you have on the front now is going to solve your issue.
drives , ideas , put , stock , truck
Anything about your 4R that just drives you crazy????? Jeff T 4th Gen T4Rs 218 02-01-2018 07:59 PM
Best prairie/grassland drives in CO? Snacksquatch Off-Roading 0 10-30-2015 01:44 PM
Crappity-crap-crap! Help, Charcoal Canister damaged! DiskDoctr Problems & Warranty Issues 0 03-25-2014 05:11 PM
Drives like a truck! PJBrendel General Discussions 9 11-22-2013 11:06 PM
Dangerous Drives on TV ryangab General Discussions 2 06-25-2010 03:09 PM
