09-03-2022, 06:15 PM
#16
Real Name: Clay
Real Name: Clay
I’ve had my maestro sitting around for a while and was wanting to jump on it soon. I came across this. Just curious. I have an 09 UR4R and my tps isnt part of my obdii.
One of the previous posters mentioned that the 09 could be read using the maestro. Is the OBDII and the inputs from the maestro different?
09-03-2022, 07:10 PM
#17
Real Name: brian
Real Name: brian
I have a Pioneer 2600nex with the maestro interface. Mine is programmed with my '08 limited. I have all the guages, tpms and CEL working with no problem. I think the issue is you need the connector that goes into the OBD2 port. I'm pretty sure that's where the signals come from.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
09-04-2022, 01:10 AM
#18
i think you can hard wire the odb wires if you understand the pin out.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
09-04-2022, 08:43 AM
#19
Real Name: brian
Real Name: brian
I forgot to mention. The connector you need should have come with the maestro.
09-17-2022, 02:04 AM
#20
Originally Posted by mott768
Hi guys my 08 4runner is the Urban runner package with that TOM TOM stereo, Its been replaced and finally got the maestroRR steering wheel controller installed with my kenwood dnx997xr Was hoping to get tire pressure read out and gauges but they arent showing up, I was able to get the gauges to work but had to flash the unit to the 08FJ cruiser to get them to work, anyone have a urbanrunner and using a maestro rr and get the tire pressure reading to work?
I have the same aftermarket stereo in an '09 V6 and it does show tire pressure data, although I'm not sure how accurate it is -- it's far more accurate to just use a normal gauge I think.
I must say that the MaestroRR unit is really cool ... I was able install a set of OEM RHS steering controls and they work perfectly. It's so incredibly simple and they've got the process really sorted out.
11-09-2022, 01:40 AM
#21
Real Name: Dillon
Real Name: Dillon
I finally worked through the differences in the Urban Runner install and an install on the other 4Runner models and documented all the differences in this thread.
2008 Urban Runner 4WD
X-REAS Delete / Bilstien 5100 + Rear FJCs
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
