Originally Posted by Drcoffee
I have an 07 Sport. Mine measured 19mm. When I went to remove the rear bracket, the bolts would not budge. They are at a funky angle backed up to the fuel tank. I gave up. Its not worth snapping a bolt and having to drill it out. Not really interested in using a torch just inches away from the fuel tank either.
Good luck
thanks for the info. i'll see if i can loosen them with a standard wrench. my 4R spent most of its life in NV so the frame is still pretty pristine
