Old 04-07-2022, 11:15 PM #1
BryanD BryanD is offline
BryanD is on a distinguished road
AC leak from Schrader valve - AGAIN!
What the heck? This is the 3rd spring in a row that my AC needs refrigerant. Each time the symptom is warm air on driver side, cold air on passenger side when the AC is on. The first time (2020) no leak was found. Second time (2021) I saw bubbling from the high pressure Schrader valve - mechanic replaced the valve. Fingers crossed problem would be solved but, no. Today was first AC day of the year. Turned it on and...warm air on drivers side. Drove home and looked at the high pressure Schrader, again it was bubbling and fluorescent. Curiously, when I went back out after dark a few hours later to look for other leaks (didn't find any), the valve was not bubbling. Anyone experience recurrent yet intermittent Schrader leakage?
2006 V6
BryanD is offline   Reply With QuoteReply With Quote
Old 04-08-2022, 10:49 AM #2
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Replace that high side pipe. Highlander shares the same part. Check ebay for parts
88710-35540 - AC Line - 2003-2009 Toyota 4Runner | Boch Toyota South
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 04-08-2022, 10:49 AM #3
eleven14 eleven14 is online now
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
2006 V6
What system was used to recharge the AC last time? I replaced my evaporator core last summer (check your AC discharge for dye btw, I had same symptoms as you) and used a rental manifold from O'Reilly and went through a few schrader valves before I realized the manifold was damaging them when opened ALL the way. Replaced the valve one last time and opened it 3/4 of the way and it solved my problem.
eleven14 is online now   Reply With QuoteReply With Quote
Old 04-08-2022, 10:58 AM #4
Drcoffee's Avatar
Drcoffee's Avatar
Well said. You open the valve just to the point it registers a pressure change. Not until it bottoms out. You can bend the valve.
Old 04-10-2022, 11:05 AM #5
Can't say for certain what system was used - my regular, faithful, mechanic did the work. But I will make a mention of the careful opening of the Schrader valve just in case that might be the problem. Thanks for the tip.
air , bubbling , schrader , time , valve
Airlift 1000 Airbags: Alternate Schrader Valve Locations steven1955 4th Gen T4Rs 9 06-28-2021 12:39 AM
Icon Rebuild: Schrader valve or Charge Port grantprior13 4th Gen T4Rs 2 03-05-2016 10:59 PM
What type of Schrader valve for the AC? skott 4th Gen T4Rs 3 07-09-2015 11:04 PM
Oil leak just below valve cover jonnieguns 3rd gen T4Rs 8 03-30-2015 12:34 PM
Valve cover leak. mitfan311 Classic T4Rs 6 06-07-2010 11:13 PM
