Originally Posted by Seasparrow
When I pull on the outer joint it looks like the inner joint rollers are in the boot not in the metal cup.
That's normal. The only thing stopping the outer part of the axle from coming out of the inner boot is the boot itself (the wheel hub also held it in place before you unbolted it). If you pull hard enough you can rip the boot and separate the axle into 2 halves.
Originally Posted by daprotege5
axle forks work great. stick it in and a couple pounds of the hammer and shes loose.
When I did my axles one of the wouldn't come out after a few minutes hammering a fork behind the axle, but I left the fork wedged in there overnight and sprayed some PB blaster on it, and when I came back in the morning it popped loose with one light tap of the hammer.
