Old 04-11-2022, 09:21 AM #1
OLD BOB OLD BOB is offline
Real Name: ROBERT DEWOODY
OLD BOB is on a distinguished road
Crank, no start
I made the mistake of buying a 4runner without checking the frame. The body was great and since I live in the west Texas desert I did not think about frame rust.
I just finished changing the frame and now the engine will not start. I can start it with starting fluid so I know that it is not electrical. It was running well prior to the swap. All fuses and the fuel pump relay are good. Good fuel pump (tried 2 different pump just to be sure) and found no power to pump. I can find no power to the relay either.
Possible something in the theft deterrent system.
All suggestions will be appreciated.
thanks, Robert
OLD BOB is offline   Reply With QuoteReply With Quote
Old 04-11-2022, 09:39 AM #2
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
thanks, Robert
Sounds like you've had a tough time Robert! Have you tested the wiring back from the fuel pump for continuity? (Low ohms setting on a meter). Also might be worth checking the ground at the pump using the same method, back to the battery or main chassis ground.
Hopefully there is someone on here with TechStream who can look into the anti theft for you, I am an ocean away so can't help there!
Edit: I just saw you have no power to the relay either, I assume you mean the 'trigger' voltage for the relay from the ECU rather than the main power in/out to the pump, as that would suggest a simple fuse to me but you checked those already.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
frame , fuel , good , pump , start
No start no crank sugjavier 3rd gen T4Rs 24 12-28-2022 06:00 PM
Crank no start thecole1098 3rd gen T4Rs 10 07-21-2018 07:44 AM
Crank no start 4runneracerunner Classic T4Rs 35 08-19-2017 04:46 PM
3RZ Crank, No Start Red October 3rd gen T4Rs 4 08-13-2016 03:51 PM
Crank, NO start... Please help! VALERIEP81 3rd gen T4Rs 7 12-15-2009 08:05 PM
