Old 04-14-2022, 03:41 PM #1
MrHoneycrisp MrHoneycrisp is offline
MrHoneycrisp is on a distinguished road
Will these 2022 Tundra wheels work?
Looking to replace the stock rims that are on my 06 Limited.
Currently have the stock 18in rims, but the previous owner did a bad job of painting them black
Toyota 4Runner 2006 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
Looking here they appear to have a positive offset of 6mm is that correct? and a width of 7.5
I am currently running 265 60r18 Toyo open country AtIII tires
I would like to purchase a set of "2022 18" Toyota Tundra SR5 OEM Factory stock wheels" per the listing
But according to this website
Toyota Tundra 2022 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
The positive offset is 60mm.
Which means the wheels will be a helluva lot closer inside and likely to rub.
Want a second opinion before I f*ck and purchase these. Would I need some spacers to make these work?
Also, looks like I would need to increase the bore size.
Only reason I am looking at doing this as I don't like the look of the black rims with the silver body paint and I want silver/grey rims.
The tundra rims are listed for $650
The other option would be to buy some aftermarket rims for around $1000...
Thanks in advance
Will these 2022 Tundra wheels work?-2022-04-14_12-35-12-jpg
MrHoneycrisp is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 03:43 PM #2
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
New Tundras are 5 lug like the Toyota 100 series Landcruiser and will not fit your 6 lug truck.
older Tundras ie 2003 ish were 15" and too small for base model SR5 16" wheels.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 03:45 PM #3
The sr5 apparently has a 6x139.7. Picture confirms it is 6 bolt.
Apparently different trim options have different bolt patterns.... not sure why toyota would do that.
Old 04-14-2022, 04:05 PM #4
camion camion is offline
camion is on a distinguished road
The 18" that came on the 06 Limited are 7.5" wide and 25mm offset.
I have an 07 Limited and am thinking of 17" rims when time comes to change them. They are very corroded.
60mm offset seems like a big change pushing inwards.
Sent from my Pixel 4a using Tapatalk
camion is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 04:25 PM #5
jacob7071 jacob7071 is offline
jacob7071 is on a distinguished road
They didn't. All 2022 Tundras have 5 lugs.
Houston, TX - 2007 2wd Limited Build Thread
Dobinsons 296/220 front and 505/705 rear, Graphite Tundra split spokes, 5th gen Tube Running Boards
Sold '02 Sport Edition
jacob7071 is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 04:50 PM #6
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
All the 2022 Tundra wheels are 6 lug. I have a pair of 2022 wheels I was going to try and run on my 2005 Tundra which has the same bolt pattern as our 4Runners.
The problem is the offset, you will need wheel spacers to clear the spindle.
You will also need wheel spacers that adapt from m12 to m14 threads as the 4runner conical lug nuts wallow around in the bore. Newer Tundra's must use m14 studs.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 04:53 PM #7
Not true… you can check Toyotas website to verify this or any website with 2022 tundra reviews.
Or the tundra forums for that matter…GEN 3 (2022+) Wheels and Tires Photo thread | Toyota Tundra Forum
Old 04-14-2022, 04:55 PM #8
You will also need wheel spacers that adapt from m12 to m14 threads as the 4runner conical lug nuts wallow around in the bore. Tundra's must use m14 studs.
Got it. Thanks for the info. Didn’t realize the difference in the stud size. I figured bore difference would be easy to change, but alternate studs would be a pain
Old 04-19-2022, 06:12 PM #9
I'm sorry, I stand corrected. I see they went back to 6 bolt, looks like for all models...and dropped the v8?
Old 08-23-2022, 04:34 PM #10
AnneMarin AnneMarin is offline
AnneMarin is on a distinguished road
I also had a lot of love for playing games and I was addicted to it. I used to waste all my time on games. Then my friend told me a link so that I could end my bad addiction. These are the link Free Essays on Addiction, Examples, Topics, Outlines - WritingUniverse If you are also addicted to such an addiction, then you can end your bad addiction. On this website, you will get free tips that how you can break your bad habits. And you can also tell about this website to those people who are victims of some bad addicton.
AnneMarin is offline   Reply With QuoteReply With Quote
offset , rims , stock , tundra , wheels
2022 Tundra or 2022 4Runner? Blackwatch 5th gen T4Rs 49 04-15-2022 06:08 PM
Looked at a 2022 Tundra bzizzi 5th gen T4Rs 2 03-04-2022 12:28 PM
2022 Tundra Gets Independent Rear Suspension and 416hp/442ft lbs V6TT Lexus Engine RichinRidgewood General Discussions 41 12-06-2020 09:14 AM
Will th 4x2 tundra work for lift. trail_runner 3rd gen T4Rs 1 09-11-2013 08:14 AM
