Old 06-14-2022, 09:18 PM #31
mr_skittle mr_skittle is offline
mr_skittle is on a distinguished road
Thanks for the info guys. Unfortunately, I'm not tuned yet. I took some time this weekend to shorten one of the defoulers but now the O2 sensor is a bit too long for it. The sensor bottoms out and basically blocks off any flow past the sensor. I have to get a 9/16 drill bit to enlarge to hole a bit more. Thank goodness the thing still runs fine because this is more than enough headache as it is. It's a work in progress I guess.
I've read through some other threads about these headers and it sounds like some folks add a different catalytic converter back in, behind the Y it sounds like. Would doing something like this help me out with this problem? Even if it doesn't I still may consider it so we can actually use the back window again without being choked out by the exhaust. The smelly exhaust is a predictable result that never really occurred to me.
mr_skittle is offline   Reply With QuoteReply With Quote
Old 06-15-2022, 09:40 PM #32
I've been thinking about my problem with the sensor bottoming out in the spacer and I'm wondering if anyone has any non-OEM sensors to recommend that may be a different length. I see that NAPA carries a Bosch sensor that is shorter than the OEM. With the current sensor/spacer combination I have, there is very little room for adjustment.
check , code , engine , headers , light
Installing Doug Thorley Headers on 2005 4.7L V8 w. 2" BL Cpt_Romania 4th Gen T4Rs 85 09-05-2021 05:22 PM
Help! 260k miles, check engine light, multi terrain light, and slip indicator light dave_b 5th gen T4Rs 21 01-19-2021 09:20 AM
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Check Engine Light, VSC OFF And Check VSC Lights just came on??? the_josh Maintenance/Detailing 5 07-15-2019 01:25 PM
Check engine light, vsc light, traction light all on after a short circuit mikeng 4th Gen T4Rs 3 01-01-2018 07:54 PM
