06-18-2022, 11:09 AM
Best rear control arms for the money?
Looking to upgrade and am wondering who makes the best aftermarket rear control arms for the money. Obviously not going to spend Total Chaos money here and I don't want heims (noisy). Also, is the factory panhard worth replacing too? Thanks dudes
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
06-18-2022, 12:05 PM
Unless you're really boogie-ing, the factory rear controls arms do alright. I have yet to run into binding issues when inspecting mine all flexed out.
Dobinsons makes some adjustable rear control arms with rubber bushings
Metaltech makes some adjustables with enduro joints on one side, rubber bushing on the other
Apache offroad is working on some rear links with poly bushings on either end and thicc tubes to prevent bending. don't think they're available for purchase
The best upgrade for the rear end setup would be a panhard correction kit. That will return your panhard to level, raise your roll center slightly, and decrease body roll
06-18-2022, 01:35 PM
Real Name: Dillon
Real Name: Dillon
X2. Quality Advice.
06-18-2022, 01:42 PM
I've just seen what happens when 1 perfectly placed rock hits a lower control arm and the uppers are just twigs. How are Rokmen control arms? Look beefy for the price
43017 - Rokmen Trail Series Lower Links for 03+4Runner/07-14 FJ Cruiser
06-18-2022, 04:24 PM
@ thegame7
If you're just looking for extra strength on the cheap, look at the bushings of your lower links; if they're in good condition, maybe try what I did on mine:
Stitch weld on some trimmed angle iron, make sure you're doing alternating lengths of stitches to reduce the likelihood of warping the links; as I mentioned in my build thread, I probably went overboard on the welding; 1-2" stitches about 2-4inches apart probably would have been more than plenty.
06-18-2022, 04:32 PM
Originally Posted by BlackWorksInc
@ thegame7
Nice that would be easy. Did you beef up the uppers too?
06-18-2022, 05:00 PM
I bent a stock lower on a silly rock.. it didn’t take much.. I built my own arms with heim joints on both sides with some DOM tube .. it’s super strong but super annoying to constantly maintain .. the adjustability is definitely nice because I had to slide my axle back about 1.5” with my 35s. If I had to do it again and didn’t need to slide the axle back I would reinforce it like suggested above.. stock quality with added beef..
I actually have considered getting the lengths dialed in and building a new set without heim joints..
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
06-18-2022, 10:21 PM
I just put rokmen trail series on my 3rd gen and I'm happy so far. Very beefy and a good price. For the panhard I second the panhard correction kit, just did that on my 3rd gen also and it's a very noticeable improvement in handling. No need for an aftermarket panhard bar.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
06-19-2022, 07:49 AM
If you play on rocks a lot something beefier would be a better, for me energy suspension did the trick because I like to keep things simple and if something brakes I can get an off the shelf solution in case I don't want to wait for parts to come in.
Been wheeling my 4R for quite sometime on my setup and can't say I've had any issues for the lack of any additional adjustments on my susp.
Got a few hits and scrubs on the arms but no bends so far.
Will be adding the PCK because we do need it on our rigs but that's pretty much it.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
06-19-2022, 07:52 AM
@ thegame7
This is actually a good idea, Great, now I got something I can do over the weekend.....
LC Prado 150
4th Gen 4Runner
1GR-FE
06-19-2022, 12:50 PM
I honestly don't see any specific reason to reinforce them against rocks since they're so tucked in there. Though you should check the bushings on those, I just recently swapped out my uppers from how badly torn up the bushings were.
I would also look into a Panhard Correction Kit, I have been pretty happy with the one I recently installed and I swear it has helped the rear end feel a bit less "wiggly" on tight turns (it's probably my imagination). I did do a quick write up on it a few weeks back or so.
06-19-2022, 05:24 PM
Real Name: Derek
Real Name: Derek
There has been a few on this site that have bent that lower arm playing in the rocks.
Another vote for the Rockmen here, i have had them on for a few years now, no noise no issues.
Did a set of the uppers from Rockauto, Mevotech, were under $30 at the time.
Actually thicker tubes than the OEMs...no issuses with them either.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
06-21-2022, 03:21 PM
Real Name: Matt
Real Name: Matt
My only basis of comparison is stock vs Dobinsons. I’ve had the Dobinsons rear adjustable lowers for a few months now. I kept the rubber bushings in them but they do include urethane if one wants to swap them. I like the bend at the axle end and the adjustability of them. Thick and super beefy too.
There seem to be a lot of great options out there though. Idk what’s really best for the money. Metal Cloak, Rokman, metal tech, Dobinsons all seem pretty competitive.
I am also running an adjustable Toytec panhard with heims. I’ll never do that again. I will be going with a stock bar and an eimkeith pck kit soon
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
06-21-2022, 10:46 PM
You guys convinced me to weld in the Eimkeith PCK yesterday Also re-valved my rear shocks to be more comfortable. Stoked on it!
