Old 05-07-2022, 11:45 AM #1
Hdhogan Hdhogan is offline
Hdhogan is on a distinguished road
random plug help!?!?
Anyone happen to know what this plug was for? It's it is wired to a relay tapped near the driver fuse panel. Wanted to clarify what it is/was before I take it out.
random plug help!?!?-20220507_082334-jpg  random plug help!?!?-20220507_081853-jpg
Hdhogan is offline   Reply With QuoteReply With Quote
Old 05-07-2022, 12:34 PM #2
Jubsz Jubsz is offline
Jubsz is on a distinguished road
Educated guess - Looks like the remnants of an aftermarket alarm install. You'd have to track the wires back to the source to verify that it connects to things an alarm would connect to.
Jubsz is offline   Reply With QuoteReply With Quote
Old 05-07-2022, 01:15 PM #3
Great, thank you!
Old 05-07-2022, 02:38 PM #4
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
That's an old aftermarket alarm system, shouldn't be too hard to excise from your vehicle. At most you may need to repair a wire or two (usually the Start and/or IGN ON wires as those get cut for the alarm to splice in between for security features).
I'd pop off the lower A-Pillar Cover, Lower Driver's Kick Panel, and steering column cover. That should give you plenty of room to trace all the wires and remove that old harness out of the vehicle.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-07-2022, 03:02 PM #5
Definitely , appreciate it. Looks like they used t-taps so hopefully not much repair required.
clarify , is/was , plug , random , wanted
P0303 - cracked porcelain on plug - replaced all plug, still misfire symptoms... DK327 3rd gen T4Rs 2 04-06-2021 04:23 PM
HELP: Random Plug Mudhorn 5th gen T4Rs 6 07-09-2020 10:14 PM
4 pole flat trailer plug- how are you storing them? plug 2ndhandyotaman 3rd gen T4Rs 5 04-04-2018 11:09 AM
Random plug DCameraMan 4th Gen T4Rs 14 04-26-2017 03:40 PM
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto Rockauto 0 01-12-2017 02:52 PM
