05-06-2022, 10:46 AM
How to get more headroom?
I love my T4R, it's my dream car, but the headroom situation with the sunroof is terrible. PS, I don't care if headroom isn't an issue for you so please save your comment.
Has anyone found a way to lower the seat more or push the ceiling up? I'm about $4k deep in mods, so trading for a GX isn't worth it. I tried the desert does it seat rises, but all it did was make my head sit even closer to the ceiling. Sitting farther back does help, but it's not as comfortable for my arms, so I also considered looking for something that extends the steering wheel closer.
I also looked into modifying the seat brackets but every shop I took it to refused to modify it due to liability issues from modifying a safety system.
Any other ideas? Anything you have tried that worked?
05-06-2022, 11:08 AM
I thought Ive seen a seat lowering bracket for the back of the seat. kind like the riser for the front
if I come across it again Ill try to share the link
05-06-2022, 11:27 AM
I'm 6'5" and daily drive my sunroof 2008 SE. I have no issues with the head room. I agree it is tight but there is no way yo solve this issue without a low profile seat and custom brackets.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
05-06-2022, 12:49 PM
I don't see how that would be possible; the back of the seat is already down as far as it can get.
One thing I did find helpful though: I added a pair of "ExtendMySeat" brackets. It's incredibly easy to do. They allow the seat to go wayyyy farther back than stock. While it's not a direct solution to more headroom, it still gives you a lot more space. Especially welcome on long road trips. Kinda spendy, but they seem incredibly sturdy and well-fabricated and they are dead simple to install.
05-06-2022, 11:47 PM
if you sit back, is your steering wheel extended out also? its not only up and down, but you can also push it in or pull it out some, unless you have some t-rex arms.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
05-07-2022, 05:28 AM
I agree OP I'm only 6ft and when my hair needs cutting I can tell because I can feel it rubbing on the sunroof 'surround'!
I can't remember this happening in any other cars I've driven with a sunroof, including small ones like a mk4 Ford Fiesta.
I know it's a raised vehicle with the 4WD driveline etc but they could have done with an few inches more roof height.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
05-07-2022, 07:11 AM
Pull your headliner out. Not the most appealing solution but apparently it adds quite a bit of space according to a few builds that installed cages in these rigs. That’s the only economical solution that will yield a little extra room.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
05-07-2022, 06:23 PM
Delete your sunroof and install a sunroof-less headliner. Pretty sure thats what
@ LTDSC
did, you'll need to check through his build thread as I don't remember the exact page and I believe he has sold his T4R now
05-08-2022, 02:19 AM
have a look here, i just did my roof so you can see some decent pictures.
Sound Deadening and New Audio Setup
05-08-2022, 12:08 PM
I'd appreciate that!
05-08-2022, 12:13 PM
I have T-Rex arms
05-08-2022, 11:20 PM
Originally Posted by ThatRed4thGen
I have T-Rex arms
i guess its time for you to drive with those ez-reach grabbers.
05-08-2022, 11:28 PM
I actually looked into steering wheel extenders haha.
05-09-2022, 01:29 AM
Depending on your year of 4Runner, apparently this is a thing:
Telescoping column conversion (DIY)
My truck only has tilt. A telescoping feature would be amazing.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
05-10-2022, 04:06 PM
For context I am 6'4", 190lbs, 34" inseam with a 2008 4runner that has power cloth seats and sunroof. Currently I have just under an inch of clearance above my head. When I was test driving 4runners I sat in one identical to the one I have now but with leather. I actually sat higher in the seat with the leather compared to the cloth seats I have now. That leather was very old, stiff and rigid which is probably why I sat a little higher. If you have stiff leather that could be something you could think about replacing.
In my younger years I actually drove a 1991 Mazda Miata and had to make some major adjustments to fit in that comfortably. What I did in the miata was take out two inches in the seat bottom cushion which allowed me to sit lower. I removed the entire cushion from the car, removed the cover, then cut an inch off the top and bottom of the cushion itself. This wasnt that hard to do if youre mechanically inclined and made it so much more enjoyable to sit in the car. I recommend you try doing that before modifying the seat attachment structure to the car.
2008 4Runner Mod List: Daystar 2.5"/1.5" Lift, BF Goodrich KO2 275/70r17, TRD Pro Rims, Spidertrax 1.25" in front and All Pro 1.5" in rear, Katzkins Seat Leathers, 15% ceramic tint, Joying 10.1" Head Unit, Remote Start, DRL Mod, Map Light Mod, Dash Cluster LED Upgrade, Area Camp Lights.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Headroom???
DPR64 |
3rd gen T4Rs |
10 |
04-19-2020 01:23 AM |
Not enough headroom
Steve Hicks |
Problems & Warranty Issues |
0 |
12-23-2014 08:29 AM |
More headroom
963rdgen |
3rd gen T4Rs |
12 |
02-22-2013 03:00 PM |
4th gen headroom
zoomob |
4th Gen T4Rs |
21 |
02-21-2013 03:31 PM |
Headroom for dog
SEWELLGT |
5th gen T4Rs |
11 |
06-09-2011 04:52 PM |
