Originally Posted by Montego Murph
You may have to use your phone as a periscope of sorts... but if you look at the "outside" of the harness (facing the drivers side) you should see what looks like a little handle. If you push the button and raise that upwards, it will release the latch and it should slide straight up.
Be VERY GENTLE with this. The pins in there may be a little stuck and you don't want to break them off. Spray it all with DeOxit and let it dry before putting it together. And rub a little dilectric grease on the seal too. You don't want moisture getting in there -- that's where like 90% of transmission electrical problems come from.
yes, i have seen the handle, even wiggled it and tried to pull it upwards, it didnt budge. you mention a button-to push. where exactly is this button?
AuSeeker
, am intouch with the author of that video, he still is unable to explain insimple terms how to unclip the harness
Dropped the pan and drained and refilled. Then did another drain and refill 500 miles later. Car drives fairly ok now, even did a 300mile round trip recently, smooth shifting. Yet error code refused to go away, erased it several times, even unplugged the battery. Also removed the suspect solenoid from the tranny and tested it.tested ok with 12v and read 14.6ohm. So i wonder what the issue is, perhaps the cable tranny or ecm side.
Am still unable to unplug the cable harness, perhaps will try and buy the replacement cable harness to see if that will give me some insight in unplugging it. just not keen on spending money buying a part i may not need
2005 v6, galactic grey 4wd auto :
pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......
sold
2004 rav4 titanuim silver 4wd auto :
pionneer avhx 5500bt hu, pyle reverse cam
