05-19-2022, 03:54 PM
#16
Wrong. The OP's .sig line indicates he has a v6 engine.
05-19-2022, 04:20 PM
#17
Originally Posted by randy88fj62
Manual states spark plug interval is 120,000 miles on page IG-2 for the V8. Then it recommends Denso Plug P/N SK20R11 or NGK P/N IFR6A11.
Gives a spark plug gap of .039-.043 inches.
The 30k statement in this thread is incorrect.
what!!!
05-19-2022, 05:04 PM
#18
Real Name: James
Real Name: James
Well, in light of differing comments here, I cracked open the Haynes Repair Manual, not entirely clear, but it may depend on the type of spark plug.
Maintenance schedule verbatim quote:
"Every 30,000 miles or 24 months, whichever comes first
Replace spark plugs (non-platinum or iridium type)"
Not sure, but this seems to mean copper every 30K, while the two others mentioned above can go longer. I've seen references on the internet (so it must be true), platinum go up to 60K miles, iridium up to 120K miles.
Any thoughts on this? Thanks.
P.S. Edit to say that Haynes does not differentiate on this between the V6 and V8.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
Reason: more info
05-19-2022, 05:48 PM
#19
I am quoting the Toyota Factory Service Manual for a 2003 4Runner. A haynes manual means nothing compared to what the Japanese published as official OEM document. They even tell you what spark plugs to use....
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
05-19-2022, 05:59 PM
#20
Real Name: James
Real Name: James
I don't doubt that, but Haynes is all I had at my disposal.
Thanks for that information.
Regards, sport2004
05-19-2022, 08:05 PM
#21
Factory replacement recommendations for 2003-2009 4Runners are 120k for Iridium Spark Plugs used in the 2UZ-FE and 30k for the Standard Resistor style plugs used in the single VVTi 1GR-FE engines. Some older Tundra and Sequoia used standard plugs, but by about 2002~2003, all 2UZ-FEs should have been specc'd for Iridiums.
You can run plugs longer, but that doesn't mean it's recommended or that they are working efficiently. I've seen people run 1GR-FE engines into the 120k range on factory plugs. But I've also seen plenty of misfire, failed coils, poor idle, intermittent issues because of that. Keep in mind that the factory gap is supposed to be something like .040", that doesn't mean that the ignition coil can't fire the plug if it's .050", but it means that the coil has to work harder and likely won't be as hot or strong as factory specification.
05-19-2022, 08:52 PM
#22
Real Name: James
Real Name: James
Thank you for this, adds much more perspective. Much appreciated.
Regards, sport2004
05-20-2022, 08:47 PM
#23
Real Name: Rich
Real Name: Rich
I have a 2004 V8 and replaced my OEM plugs at 98,000 miles with iridium plugs, Denso SK20R11. I went to Advance Auto at 60,000 and was advised to wait until I was at 100,000 since they were iridium.
My owners manual says to use only iridium plugs and not to gap them.
However the specifications section says .043" is the gap.
Replacement: 60,000 miles or 72 months
V8 Denso SK20R11, NGK IFR6A11
V6 Denso K20HR-U11. NGK LFR6C11
So bad advice from Advance Auto. I'll be replacing the plugs pronto. I tow a 23' aluminum travel trailer of about 6,000 lbs. and my 17' bass boat, about 2,000 lbs. I've not had any issues with idling or acceleration. gas mileage remains the same, in town or on the highway.
I have been told that the spark will most certainly make the necessary arc to ignite the fuel mixture but idle can suffer and the engine may even stall when slowing to a stop. I've not had that experience.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
05-20-2022, 08:57 PM
#24
Real Name: James
Real Name: James
Thanks for this input. Looks to me like you're doing the right thing.
Regards, sport2004
05-20-2022, 09:01 PM
#25
Real Name: Rich
Real Name: Rich
From the NGK site:
"Traditional Single Iridium Plugs Denso's Iridium Power and NGK's Iridium IX series have iridium fine-wire center electrodes with tranditional nickel ground electrodes. The ground electrode will wear out first. Typically we have found you can expect 50-80k miles on a traditional iridium plug. But plug manufacturers have to temper their projections as driving conditions and motor modifications differ. Additionally, because gradual wear will "round-off" firing points over time, the concentrated firing power and voltage requirement benefits will be reduced. Therefore, NGK gives them a life expectancy of 40-50k miles and Denso assigns a recommended replacement interval of 30k miles."
Rich
Kentucky
05-20-2022, 09:11 PM
#26
Real Name: James
Real Name: James
From the NGK site:
Interesting, and thoroughly confusing...LOL
Regards, sport2004
05-20-2022, 09:15 PM
#27
Real Name: Rich
Real Name: Rich
Totally confusing, especially since my T4R came with Denso plugs and I can't find the NGK plugs. I'll follow the manual and get the Denso plugs, change at 60,000 going forward. YMMV
Rich
Kentucky
05-21-2022, 05:16 PM
#28
Real Name: Skip
Real Name: Skip
From the NGK site:
Just an FYI, any manufacturer is going to "underestimate" the life of their product so they aren't held responsible for premature failure, both NGK and Denso long life versions of the iridium plugs will easily last 60,000 or more miles.
2004 Limited V8
05-21-2022, 05:52 PM
#29
Real Name: James
Real Name: James
Thanks, Skip...
Not to be cynical, but could also enhance sale volumes.
Regards, sport2004
Reason: added comment
05-22-2022, 12:03 AM
#30
I wonder why the difference in recommendations? I would imagine if Toyota thought the Iridiums couldn't last 120k, they wouldn't recommend it. i.e. the direct injection engines recommend 60k intervals on their plugs.
