Old 05-16-2022, 02:04 PM #1
sport2004's Avatar
sport2004 sport2004 is offline
Real Name: James
sport2004 is on a distinguished road
sport2004's Avatar
Real Name: James
Slow Ignition Solution?
I love the ignition system on my '04 Sport. Quick turn and quick start-up. However, recently I noticed the engine doesn't start quite as quick as it used to, and one time it didn't actually start first time and I had to turn the key again for it to do so. I know terrible, right? LOL
Anyway, is there anything I can or should do to tweak this? Is this a sign it needs some minor maintenance to get it to start right up like it used to? Currently sits at 144,000 miles, runs like a top, and the engine hasn't needed anything other than routine maintenance.
Any insight appreciated, thanks.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
sport2004 is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 02:10 PM #2
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
If the engine cranks but doesn't start right away I think the computer makes adjustments to fuel and timing. I'm not well versed in that area but I believe that's what's happening. If it's persistent and the engine is running fine otherwise, then maybe take it in and let them run some diagnostics on it.
Do you notice any issues with performance or lower gas mileage?
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 02:18 PM #3
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Thank you. I was noticing some minor issues with these, but was running with a bad exhaust system and have since taken care of that, replaced nearly the entire configuration.
Minor thing, but I would like to follow up if there was room for improvement.
Regards, sport2004
Old 05-16-2022, 09:54 PM #4
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Test the battery, check the battery connections for corrosion. It also wouldn't hurt to verify that the air filter is relatively clean, and maybe clean the throttle body out (note- for best results, disconnect the battery for 5-10 minutes after cleaning, also after you clean the throttle body, it may stumble/not start the first time as it's going to need to relearn idle adjustment)
Those are the usually things I'd say to check on an older/higher mileage vehicle, after that you're starting to get into more technical diagnosis of the starter and such.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-17-2022, 09:29 AM #5
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Thanks a bunch for this response. The battery is long overdue to be replaced (I've been meaning to do so for at least two years), but even in this cold Midwestern Winter climate, it just won't outright fail. But, I'll bet there is a strong possibility of diminished function. It's time, I'll report back on that.
Another thing I was wondering is what about the spark plugs? Who knows how old they are. Meanwhile, I am cycling through some Seafoam, will see what that does.
Regards, sport2004
Old 05-17-2022, 11:52 AM #6
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
-battery
-corroded cables to/from battery
-starter contacts (copper tarnishes and the contacts wear)
-dirty intake due to lack of maintenance (ie egr valve)
-spark plugs
-coils
The list goes on and the truck treats you as well as you treat it. I have 526,000 miles on my 2008 V8 sport and it runs perfect but I also put in a bunch of preventative maintenance using OEM parts.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 05-17-2022, 12:21 PM #7
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Originally Posted by randy88fj62 View Post
-battery
-spark plugs
-coils
Thanks much for the comment. Complete random thing, but the Runner won't start. Pretty sure it's the battery, but if something else I still need a new one anyway. Should be done in a few hours, Interstate 24F. I'll tell the installer to spruce up all related connections, etc. Will see how it goes.
Regards, sport2004
Old 05-17-2022, 07:29 PM #8
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Looks like the problem is resolved. Switched out the battery, didn't get the one I wanted. (Sad tale, I'll put it in my signature thread.)
Anyway the Runner starts up pretty good again. But, went for a spin and noticed the idle was too low. I researched it and learned how to re-set the idle after the battery replacement, very simple procedure and it worked like a charm. I panicked for a while there, because my head is still in the '70's...LOL
Here it is for anybody interested, very simple, and was amusing to hear the computer "thinking" while I waited for it to finish.
https://www.youtube.com/watch?v=4xm-UpLO9tk&feature=youtu.be
Regards, sport2004
Old 05-19-2022, 08:19 AM #9
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Seafoam isn't going to fix poor maintenance. Those plugs have a 30k mile change interval. May as well check the coil boots for damage from spark leakage, too.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 05-19-2022, 08:32 AM #10
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
how accurate is this statement? the original plugs went 100k before changing, the second also. at 30k with the third set.
rwh963 is offline   Reply With QuoteReply With Quote
Old 05-19-2022, 08:35 AM #11
hey, what do you mean by the throttle body out? i recently cleaned my throttle body on the air cleaner side. i did not disconnect the battery (you might recall i started a hesitation thread).
Old 05-19-2022, 09:11 AM #12
See owner's manual to determine accuracy.
Old 05-19-2022, 09:29 AM #13
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
OK, I don't know, but from reading here and elsewhere, 30K seems low. I will check the manual.
Regards, sport2004
Old 05-19-2022, 12:05 PM #14
Manual states spark plug interval is 120,000 miles on page IG-2 for the V8. Then it recommends Denso Plug P/N SK20R11 or NGK P/N IFR6A11.
Gives a spark plug gap of .039-.043 inches.
The 30k statement in this thread is incorrect.
Old 05-19-2022, 12:23 PM #15
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Thanks!
Regards, sport2004
ignition , maintenance , quick , start , time
So my 4runner is SLOW...I mean, REALLY SLOW...advice!?? jarnld Classic T4Rs 41 08-06-2016 03:31 PM
New ignition lock cylinder - won't engage ignition - 1996 base CanadaEh 3rd gen T4Rs 2 07-26-2016 03:18 PM
Solution too 4wd "not engaging" my symptoms and solution MR.H 3rd gen T4Rs 3 02-23-2014 01:12 PM
Probably a simple solution. (ignition problem) echoes78 Classic T4Rs 2 01-16-2012 02:18 AM
Slow Start / Hesitation Ignition Problem. Any Ideas???? baronvdb Problems & Warranty Issues 20 08-07-2009 11:58 PM
