05-22-2022, 07:23 PM
#17
2019 TRD ORP. BFG KM3 285/70R17. Hefty front tube bumper, LFD dual swing-out rear bumper. Warn Zeon 10S. RSG sliders. Sherpa roofrack. Goose Gear interior. Radflo 2.5 suspension.
05-22-2022, 08:08 PM
#18
Originally Posted by Old Tanker
Lol I have these! I was wondering if there is a version for 3 vs just 2?
05-22-2022, 10:16 PM
#19
You could do a wire splice and then heat shrink it so it looks like two into one.
https://www.youtube.com/watch?v=D4b_gSciGIg
05-24-2022, 08:27 AM
#20
Originally Posted by ThatRed4thGen
Thanks for the advice! On using the Amazon power box, how do you still get things to work without tapping anything? Like for example, having the raptor lights only come on with the marker lights are on.
The switch panel has a control box that you place inside the cab. I have an 8-gang switch panel, they have other options for less inputs. ( Amazon.com: Auxbeam 8 Gang Switch Panel, Universal Circuit Control Relay System Box with Automatic Dimmable On-Off LED Switch Pod Touch Switch Box for Car Pickup Truck Jeep Boat UTV SUV, BA80 Blue 2 Year Warranty : Automotive)
you label each input you have an just use the control panel to turn them on and off. If you absolutely need auxiliary lights to trigger on and off when you put on, say your running lights, or something, then the solenoid trigger method is the route for you.
Military splicing, heat shrink, yada yada, all of that is fine and good, certainly significantly better than those crimp t-taps, but there are more proper ways of handling wiring.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
05-24-2022, 11:57 AM
#21
It's on my wishlist. Blame my horrible mean family
05-24-2022, 01:05 PM
#22
The factory wiring is designed for factory equipment. I would only use a tap to trigger a dedicated relay to the new lights. Wire the power directly from battery. And make sure you coat the tap connection with dielectric grease or silicone otherwise the green line will corrode and fail over time. Better yet, solder the connection and coat it in grease/silicone
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
05-25-2022, 12:30 AM
#23
Should I coat the T tap in silicone?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
