Old 06-05-2022, 03:21 PM #1
Bigshankhank Bigshankhank is offline
Real Name: Tyler
Bigshankhank is on a distinguished road
Real Name: Tyler
Downhill Assist Malfunction
Being a flatlander in FL, I have not used my DAC on my truck except a few times just accidentally hitting the button. Well I am visiting family in central TX and with the illy roads I decided to see if it did anything. Mind you I was in 2WD, not 4lo/AWD so the light flashed on the dashboard and beeping started, once I realized it wasn't doing anything I clicked the button again and the flashing light went away. Except the beeping didn't stop. Now I cannot stop the beeping and I have a 1200 mile drive home starting tomorrow and I am going to lose my mind if I can't get it quiet. I will literally pull the appropriate fuse if it helps but I can't figure out which one it is.
Any suggestions? Ideas? Thoughts?
2008 4Runner SR5 V6 4WD
Bigshankhank is offline   Reply With QuoteReply With Quote
Old 06-05-2022, 03:25 PM #2
Real Name: Tyler
Real Name: Tyler
Forgot to mention the VSC/TRAC lights are on, have been for years, never bothered me and never made a difference in driving the truck.
Old 06-05-2022, 03:30 PM #3
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Were you on a road? DAC is for off-road use & only works in 4LO so that explains why nothing happened. Can’t help you with the beeping, but I’d start with cycling through all the 4WD modes.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 06-05-2022, 03:56 PM #4
Real Name: Skip
Real Name: Skip
Maybe if you can track down where the "beeper" is you can try and disconnect it?
2004 Limited V8
Old 06-05-2022, 03:56 PM #5
Real Name: Tyler
Real Name: Tyler
That was my first instinct, once I realized the beeping wasn't going to stop I switched to 4Hi and pressed the DAC button but it didn't do anything. I have also disconnected the battery and left it that way for about 20 minutes to allow the ECU to reset. No improvement. I'll try it in 4LO next, luckily the roads in this neighborhood are caliche.
Old 06-05-2022, 09:17 PM #6
mjg514 mjg514 is offline
Real Name: Matt
mjg514 will become famous soon enough
Real Name: Matt
@bluesky 07 is spot on - best bet is to just be patient and try cycling through all of the 4wd modes. Good luck. Let us know how it goes.
2007 SR5 V6 4x4 / Front Suspension: OME 884/90021 + SPC UCA's / Rear Suspension: OME 895/60004 / Tires: 285/70r17 BFG K02's (C Load) / TRD Pro Wheels / Apex Overland Front Recovery Points / Desert Armor Ninja RTT / Outgear Solutions Low-Pro Crossbars
2017 TRD ORP / Watch this space....
mjg514 is offline   Reply With QuoteReply With Quote
Old 06-05-2022, 10:53 PM #7
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
I've owned my 4th gen since 2008 and I've actually used the DAC exactly once, just to see how it worked when it was new. I don't like the noise it makes and I prefer to control the brakes when I'm off-road. Just my $.02
As for your issue, it sounds as if the transfer case is between drive modes. Generally, just bumping the DAC button doesn't cause it to beep (my dog smashes that button every time he gets in or out, lol). I would try to cycle the 4wd modes and see what that does. Ultimately, the fix may be getting the cause of the VSC/Trac lights repaired, whatever that is.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 06-06-2022, 08:10 AM #8
Real Name: Tyler
Real Name: Tyler
Managed to find some undeveloped roads nearby and cycled 4wd on and off a few times including locking the diff and engaging DAC and actually letting it work a couple times and the beeping finally quit. What a pain, crossing 300k miles has been painless up till now.
beeping , button , light , mind , stop
Downhill Assist 4runner423 4th Gen T4Rs 0 04-02-2014 05:56 PM
Downhill Assist is wonderful juneau92 4th Gen T4Rs 28 12-15-2010 03:38 PM
Noisy Downhill Assist oreogaborio 4th Gen T4Rs 8 04-12-2010 01:32 AM
Does downhill assist really do this? TeryT 4th Gen T4Rs 17 07-17-2006 06:53 AM
Downhill Assist Control and Hill-start Assist Control Thai 4th Gen T4Rs 0 12-06-2002 08:37 PM
