Originally Posted by Jakeepoo3
Experience and knowledge. $2000 worth. O2 sensor is a ECM input thus your ECM code. O2 sensor is an input to skid ECU through ECM. Skid ECU disabled without O2 sensor input. The abs code is due to your disabled skid ECU. The braking problem you had is due to your skid ECU not getting proper input signals and it disabled itself. Your brakes still work right?
Yes, the brakes seem to function properly. After installing the new O2 sensor & trying to pry one of the ABS sensor out (started to crack the case so stopped) I cleared the codes and drove about 5 miles to the auto part store. New codes:
C0200 Right ABS sensor malfunction
C0205 Left ABS sensor malfunction
C1223 General ABS system fault
C1241 Low battery positive volt
C1256 Accumulator Low Pressure...Confession: This might have occurred because I tested the brake by pumping them 7 to 8 times while idling and the ABS warning light came on and it buzzed. Unfortunately the Accumulator is already on order.
I wish I had techstream ->
Procedure to troubleshoot C1241 Low Battery Post Volt.
