Three times C0606 Engine Control Module Processor.
P0137 O2 sensor bank 1 sensor 2 low volt.
C1201 Engine Control System Malfunction.
C1233 Malfunction in antilock brake system control system.
C1241 Low Battery Pos Volt.
C1256 Accumulator Low Pressure.
Maybe I should clear the codes and then drive it to autozone/advanced auto to have them check for current codes?
Originally Posted by Jakeepoo3
I've also had that code after neglecting to re calibrate my zero points after a 3" lift. Mine did what you said on a sharp right turn and nearly killed a granny.
Interesting. I do have a 3 inch-ish lift.
