Old 06-16-2022, 01:51 PM #1
joefrog003 joefrog003 is offline
joefrog003 is on a distinguished road
P0430 keeps returning after replacing multiple O2s and converter. What now??
Here's the scenario so far:
Got a P0430 code so I replaced the O2 sensor with a Denso model. Code retrurned a year later so I replaced the sensor again with another Denso. Code retruned within a month, so I took it to a muffler shop in town and they replaced the downstream drivers side converter. While he had that coverter off, he shined a light at the upstream converter and said it at least appeared to still be good. That was last week, and now today I just had the P0430 return.
Short of replacing the upstream manifold/converter, I'm at my wits end as to what to do next. Any ideas?
joefrog003 is offline   Reply With QuoteReply With Quote
Old 06-16-2022, 02:27 PM #2
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
yes, replace the first CAT or check if there are any leaks there.
4r-4ever is offline   Reply With QuoteReply With Quote
Old 06-16-2022, 09:30 PM #3
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Have you had anyone with a scantool actually check what the fuel trims and sensor readings are for Bank 2?
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 06-17-2022, 08:54 AM #4
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
I could be wrong here... but my gut feeling is the muffler shop was just throwing an easy replacement on to see if it will fix the issue.. If you haven't replaced your upstream converter/header that is more than likely your culprit.
I do second the thought on scanning the fuel trims across both banks just to verify but am leaning highly towards a failing/old cat. If you're not looking to have it replaced you could always try the O2 spacer/spark plug nonfouler route to get the sensor out of the exhaust stream a bit to reduce the amount of reading it puts out. Has worked fine for me for the past year. There is a recent active thread on this around here some where. This would work considering that your upstream o2 sensor is fully functional and isn't causing screwed fuel trims.
ps: as a side note... not that I'm a exhaust technician or anything... but shining a light up the exhaust to evaluate the condition of a catalytic converter seems far from the best way to determine if its still efficient enough to fall within spec of what your ECU is looking for..
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 06-17-2022, 11:08 AM #5
Jmoore Jmoore is offline
Jmoore is on a distinguished road
I just went through this exact scenario. I first replaced both drivers side a/f and O2 sensors. Code’s kept coming back after a month or so. Ended up replacing the manifold/cat with aftermarket. Still didn’t fix the problem. Replaced the aftermarket manifold with oem and now the code is finally gone.
Stock 2008 4 Runner SR5
Jmoore is offline   Reply With QuoteReply With Quote
code , converter , p0430 , replaced , sensor
Replacing Cat Converter in California keith.z 3rd gen T4Rs 58 10-06-2023 01:19 AM
Replacing Catalytic Converter - Any tips? jacobswetsuit 4th Gen T4Rs 1 02-13-2021 09:32 AM
*Clean Out* 2017 TRD ORP Stock Parts Multiple Items Multiple Prices - Tyler, TX bmy1287 For Sale: T4R Items 1 11-30-2020 08:39 PM
Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix Warwicke36 4th Gen T4Rs 26 05-14-2020 10:37 PM
P0420 for 2nd time in a single year after replacing catalytic converter wmessin Problems & Warranty Issues 3 10-29-2010 03:02 PM
